04.05.2007, 11:54 PM
how does this sound? Does it sound doable, safe, reliabel, and not to hot
Differential Ratio: 3.3076923076923075 (buggy)
Transmission Ratio: 1.7222222222222223 (second gear single speed)
Other Ratio: 1
Spur Tooth Count: 51 (strobe)
Pinion Tooth Count: 16 (mod one)
Total Voltage: 19.2 (16 cells )
Motor KV: 2200 (Neu 1515 1y)
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.006
Spur/Pinion Ratio: 3.19 : 1
Total Ratio: 18.15785 : 1
Tire Circumference (inches): 18.22 inches (462.82mm)
Total Motor Speed: 42240 RPM
Vehicle Speed: 40.14 MPH (64.48km/h)
Effective Speed Rate: 2.09mph/V (3.36kmh/V)
Effective KV Value: 2200
