jhautz
jhautz's Avatar
04.06.2007, 03:42 AM
Originally Posted by Serum
there are several threads in this savage forum, but for some dumb reason there is a timestamp on them.. Check all the posts from the beginning..
Yea I think I read them all tonight...:024: Learned alot, but still have a few questions while I decide if I am going to bite this off.
Right now I'm thinking about buying a Savage X roller so the steel spur shouldnt be an issue.
-What are the differences between the X and the X SS besides the motor and the fact that its a kit vs a RTR?
-So no transmision or drive train upgrades are needed with the exception of the Aluminum diff cups you mentioned. Bonus.:027: Does the stock transmision 2 speed need to be upgraded or changed to work with brushless? HD 2nd gear?. Obviuosly I would need to keep the mechanical brakes if I keep the 2 speed. But, can it be locked into 2nd (like an emaxx) so I can just use motor braking? (probably won't at first, just wondering how difficult it is)
-As for motor mounts...(electric obviuosly) I've seen them done by mounting them in betwen the side plates and I'v seen them done by making an angle plate with holes that line up with the mount holes for the nitro engine. Any advice on which is better?
-Are the GPM bulks going to be necessary or just a nice upgrade. Is this the weak point?
to make it...
or break it...
Silent...But Deadly
