jimbob
04.06.2007, 07:33 AM
this mount would use stock holes and make the diff sit on top of the chassis using the stock motor mount cut in half ?? (should be strong enough hopefully)
left is the front mount
right is the back mount
with this design all you need is some 5mm metal or plastic and a drill press
cut one section 26mm by 45mm and the other 26mm by 26mm
then drill the 16mm hole for bearing in correct position
im currently going to get some plastic of some kinda and try and make it to see how well it will work...
it does move the drive cup positions so im hoping the dogbones can still be used :018:
