xjbebop
...so much to learn...
04.06.2007, 05:49 PM
Originally Posted by suicideneil
The stock bellcrank is pretty good- its the actual servo & white plastic saver that are poo-poo. I would go onto towerhobbies and order the 'Kimborough servo saver for large gas truck' and the a hitec hs645mg servo- that is what I and alot of other guys use and its a perfect combo. There are other servos available but that one is a great buy-
http://www2.towerhobbies.com/cgi-bin...&I=LXUZ89&P=ML
and the servo saver-
http://www2.towerhobbies.com/cgi-bin...&I=LXS443&P=ML
both those will set you back about $41 + p&p- not bad at all really.
Good info! Thanks!! I hadn't heard of the Kimbrough saver. I picked up each of these at my lhs on the way to work for $45 total. I'll get 'em installed tonight or tomorrow and report back.
