Serum
Serum's Avatar
04.08.2007, 04:33 AM
End to end isn't the way to solder them together, unless you are using a tube to do it. Side/side soldering is better. even better is using the female plug of a 4mm plug (make it shorter using a dremel if needed) and solder both ends into that.
