squeeforever
squeeforever's Avatar
04.09.2007, 12:43 AM
Well you should have came here first. Then you would have only had to buy 1. :p Personally, I would go with 14 or 16 cells with the 7020 and a 9XL. That shouldn't pull to many amps and should be safe. The 9L will pull a good bit of amps and make the controller a little hot.
