glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.09.2007, 11:09 AM
Originally Posted by furu
The problem with ballooning tires should be solved by using correct diff oil, shock oil and a good setup for the truck/buggy/car. Adding tape or mesh to a tire adds weight, and that's usually not what you want if you're racing.
If you just add tape the tires will still be up in the air spinning and not on the ground. Having lots of power doesn't help if you can't use it correctly.
That's pretty much a direct quote from Adam Drake ;) and it is true for racing.... but that doesn't apply to doing speed runs and bashing... that works on the track (short bursts of speed and power)
But at a certain speed, tires will balloon no matter what setup is on the vehicle.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
