04.10.2007, 10:58 AM
The 2600 is just a "hotter" wind which will be faster on the same battery and gearing but also suck more juice and everything will run hotter. But of course you can gear it down and reduce the heat (and speed)
Between those two motors you can more or less make them run the same by adjusting the gearing. If you go with the 2600 just expect to run a smaller pinion than you would on the 2000, that's all.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
