glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.11.2007, 11:22 PM
The idea is to completely drain the battery... dead... flat. AT that point there is no danger because there is no charge (energy) left that can do any damage.
Any method you want to use will work, as long as it gets the battery to 0 volts.
Again.. the saltwater bath has been way overhyped imo and is outdated. (If you can find other ways to dump it dead)
I like the idea of using a nimh discharger... that will let you dump all the way.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
