04.13.2007, 05:32 PM
I don't know. I don't have a Quark, but just going by the specs, I would have gone for the MM if all you are running is 4S. As everyone said, you'll just have to check it out. The only advise I can give is to keep the rolling resistance to a minimum. Don't get crazy with the size of the tires, keep the truck light, and use conservative gearing. I toasted a Mamba Max last night on 5S because I went too big with the tires and tried to gear too much.
