04.13.2007, 11:14 PM
Charging through a balancer will only take longer if any cells have to be balanced because it does place a small load on the high cells. And the LBA10 seems a tad sensitive so it balances more often. However, the load the LBA places to balance is relatively small and should not affect charge time too much (maybe 30 seconds) unless charging lower capacity cells.
BTW: Those numbers seem fine to me...
