Thread: tuning problem
neweuser
neweuser's Avatar
04.16.2007, 03:59 PM
I would personally richen the low needle and check the pinch as squee said. If it's cold, and needs a rebuild, most likely it would run till it got hot at least then kill.
You can check the compression fairly easy though.
Another reason might be air lek. How long has it sat for?
