MGM ESCs initial setup - beeps not happening..
fkadir
MGM ESCs initial setup - beeps not happening.. - 02.13.2008, 05:25 AM
Hi Guys,
Managed to get the ESC hooked up now and trying to initialise the ESC.
I pull the throttle all the way forward and switch on the ESC and wait there for 10 seconds for the 3 expected beeps.. but nothing!
I can see the ESC powered up and comms with my PC is fine.
Any pointers?
Thanks!
wallot
wallot's Avatar
02.13.2008, 05:26 AM
do you have motor connected? ESCs beep through the motor :)
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
fkadir
02.13.2008, 05:36 AM
Yup, got the motor connected up and running.
myndseye
myndseye's Avatar
02.13.2008, 10:07 AM
You have probably got the signal to your esc backwards. If you servo reverse the throttle on your radio, and reverse two of the wires on the speed control to the motor, it will probably get you corrected.
fkadir
02.13.2008, 10:14 AM
Cool! Followed your instructions and it works! I reset-ed my servo settings on my m11 and switched 2 wires on the speed control, the motor beeps as required now. Thanks myndseye!
