This instead of FLM conversion?
This instead of FLM conversion? - 02.24.2008, 01:52 AM
http://www.neweramodels.com/item.cgi...=&part_id=3372
i realize it would take some fabbing for batt and motor and esc mounts, but this thing is HUGE! maybe i should get a set of savage axles off of ebay. maybe a mega 22/45/2 and a sentilon 100a esc on 10s to 12s? maybe the zippy-r packs? what do you guys think?
02.24.2008, 01:14 PM
Go with the flm kit, much better IMO, plus it has the motor mount and battery tray already setup. I would post some pics, but I am waiting till I get it complete
02.24.2008, 01:16 PM
well, i would like to run 10s most likely and you cant fit that in the flm kit.....
jhautz
jhautz's Avatar
02.24.2008, 01:31 PM
I can fit 5s 8000mah truerc pack in mine. They are made from 4000mah cells in a 5s2p configuration. So you should be able to fit 10s 4000mah.
Dont get me wrong... Its a tight squeeze, but they do fit nicely.
to make it...
or break it...
Silent...But Deadly
02.24.2008, 01:39 PM
what would be the best manufacturer that makes a 10s pack that i could fit in there?
02.24.2008, 01:43 PM
I would buy a pair of 5s packs and run them in series. Maybe some flightpower lipos, like the 3700 cells.
jhautz
jhautz's Avatar
02.24.2008, 01:47 PM
I don't think you will find a whole lot of options on factory built 10s packs. You will probably be better off going with 2x 5s packs wired in series. You could just put another layer of heatshrink over the 2 packs to tie them together and you can handle them like 1 pack.
ANother thing to think about is charging a 10s pack. There arent alot of chargers out there that charge 10s well. 2x 5s packs might be asier to handle in this regard also.
EDIT: Pimp is a faster tyepr then me.....
to make it...
or break it...
Silent...But Deadly
captain harlock
RC-Monster Captain
captain harlock's Avatar
02.24.2008, 02:40 PM
Just an input to the NEM chassis conversion.
A major change should be also applied to the spur gear.
The Mod1 spur gears used in the Savage will not tolerate the force used to move a Savage that's 5" longer than the normal truck.
I believe the spur will get stripped under pressure in a very short while.
Nice to meet you!
cart213
cart213's Avatar
02.24.2008, 03:03 PM
The SS Savages use steel spurs. Surely those wouldn't strip out. I assume you're referring to the plastic spurs?
t-maxxracer32
t-maxxracer32's Avatar
02.24.2008, 03:36 PM
ya know... ive heard people talk bad about steel spur steel pinion but i run it on my xt8 and LOVE it.
sure its a little louder but ive had so many times when the motor gets knocked loose and theres HORRIBLE mesh. but no strippage
i dont think ill go to plastic/steel or anything else.
02.24.2008, 03:45 PM
well, heres what i got with 49/12 gearing (cant find a spur bigger than 49t for the savage x model, i will be buying the x ss kit w/o engine)
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1.5833333333333332
Other Ratio: 0.967741935483871
Spur Tooth Count: 49
Pinion Tooth Count: 12
Total Voltage: 37
Motor KV: 1380
Tire Diameter (inches): 7.5
Tire Ballooning (inches): 0
Motor Current Draw: 60
Motor coil Ω: 0
Spur/Pinion Ratio: 4.08 : 1
Total Ratio: 20.69531 : 1
Tire Circumference (inches): 23.56 inches (598.47 mm)
Total Motor Speed: 51060 RPM
Vehicle Speed: 55.05 mph (88.43 km/h)
Effective Speed Rate: 1.49 mph/V (2.39 kmh/V)
Estimated Adjusted Speed: 51 mph (82 km/h) - 7% loss
Effective KV Value: 1380
Motor Torque: 0.31 ft-lbs
Final Torque: 6.34 ft-lbs
Final Power: 2220 watts (3 HP)
i always thought a 20lb truck at 55mph would be cool.... especially hearing it shift into 3rd..... mmmmm..... hopefully flip over wheelies in 1st.
t-maxxracer32
02.24.2008, 05:53 PM
it may not actually do 55 thats just in theory.
if you do let it hit 55 please get a video of it crashing
02.24.2008, 05:54 PM
will do. what motor do you guys think the 45/2 is eqivelant to?
jhautz
jhautz's Avatar
02.24.2008, 06:11 PM
Your joking... But I had my Savage clocked on GPS last summer at 52mph and it was very difficult to manage. I could see the crash at that speed being very spectacular.
to make it...
or break it...
Silent...But Deadly
tashpop
02.24.2008, 05:57 PM
the 22/45/2 is equal to badass. at least it seems so far in my build.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
