I Need Motor Help!!! -
03.10.2008, 09:02 PM
iight guys im doin a muggy conversion and i was goin to just do a 10xl but my original plan was for a 1521/1y. but now im confused decisions, decisions, decisions. well anyway i need some help im goin to run 6s no hv setup for me not yet. but my motor choices r the 10xl, a 1521/1.5d, a 1521/1y, or the 1527/1d( i kno its a high kv motor its like 2100kv and will prolly draw crazy amps but it should still be a torque monster) have a neu 4900 25c that will be in the truck and it a decent battery so it needs a good motor. coming guys help me out here.
03.11.2008, 04:25 PM
Racing or bashing?
6s esc limits your options to a handful of controllers- Quark, MGM, Jazz maybe, or the MMM, unless you can live with a forwards only + mech brake setup = airplane escs at your disposal.
I think a lower kv like about 1500-1700 for 6s, then with those larger Neu 1521 motors you will have greater torque for higher gearing, and speeds easily in excess of 40mph+, with cooler temps and longer runtimes to boot.
The battery you have is a 6s item I take it?
03.11.2008, 08:33 PM
i really don't know why there would be a toss-up between the nue motors or a feigao. seems like an easy decision if you're willing to spend the money.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
03.11.2008, 09:29 PM
well at first it was easy at first just get the neu and then i became hard when child support hit me for almost 330 a week but im thinkin since im goin to do it do it right but im thinkin the neu 1521/1.5d the 1860kv do u think this would be a good 6s motor or should i go with the 1521/1y that mike sells
That's All Folks!
03.11.2008, 09:39 PM
I think either motor would be great, it may boil down to what you can find in stock.
03.12.2008, 05:46 PM
ordered the 1521/1y i hope i like it i wanted to 1521/1.5d so ill see how it is
03.13.2008, 04:22 PM
muggy mounts are available
03.20.2008, 02:14 AM
03.20.2008, 08:20 AM
Great vid!
I’m curious how that crazy torque in your vid translates on paper (using BrianG’s calc)? What’s your muggy’s front/rear diff gearing and tranny gear ratio? I’m interested to see what your calculated mph and ft-lbs torque equal versus what was seen in your vid…
~Thanks…
03.20.2008, 10:44 AM
the muggy diff ratio is 4.09
the pinion was 22
the spur is 46
That's All Folks!
03.20.2008, 10:49 AM
Hard to believe it is 22/46 (according to vid) gearing!
Differential Ratio: 4.09
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 22
Total Voltage: 22.2
Motor KV: 1577
Tire Diameter (inches): 5.7
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.008
Spur/Pinion Ratio: 2.09 : 1
Total Ratio: 8.55182 : 1
Tire Circumference (inches): 17.91 inches (454.84 mm)
Total Motor Speed: 35009.4 RPM
Vehicle Speed: 69.42 mph (111.51 km/h)
Effective Speed Rate: 3.13 mph/V (5.02 kmh/V)
Estimated Adjusted Speed: 63 mph (101 km/h) - 10% loss
Effective KV Value: 1577
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified.
03.20.2008, 11:27 AM
Strange, that doesn’t seem to add up…
At max voltage the 1521/1y is rated to draw 75amps. With your configuration (at least according to BrianG’s calc) that’s only 2.86ft-lbs torque with a crazy top speed of 63mph. The smaller torque number is what’s strange. Your vid clearly didn’t look like only 2.8ft-lbs torque as you were easily pulling the front-end a decent speed.
That's All Folks!
03.20.2008, 01:12 PM
max amps = watts/your voltage; more like 135 amps
03.20.2008, 01:44 PM
^not this again. Nobody can seem to explain this to me. Sorry for the noob lack-of-understanding here; but how can you calculate your watts without having an amperage figure?
Where is the 2997w figure coming from?
That's All Folks!
03.20.2008, 01:57 PM
Max watts of motor is 3000, But to be accurate you would need an eagle tree or other accurate amp reading.
Linear Mode
