Are the e-maxx extended chassis and t-maxx extended chassis Mike sells interchangable
Are the e-maxx extended chassis and t-maxx extended chassis Mike sells interchangable - 04.13.2008, 05:07 PM
I think that both of these chassis have the same mounting setup..has anyone have experience w/ both..
http://www.rc-monster.com/proddetail...chassis&cat=17
http://www.rc-monster.com/proddetail...LM16040&cat=45
83gt
04.13.2008, 06:17 PM
I'm sure they're not quite the same. T-Maxx is wider in the center if i'm not mistaken.
J.
jhautz
jhautz's Avatar
04.13.2008, 07:17 PM
The bulks for the T and E are the same so I imagine the chassis bolt up would be the same too. I would think it would work. But I never had a t-maxx so Im not really sure.
to make it...
or break it...
Silent...But Deadly
04.13.2008, 07:25 PM
I have a t-maxx w/the hybrid bulk Mike sells from Fastlane Mach...and am probably going to buy the Fastlane chassis and run a center diff and hopefully Mike can make me a mount for the motor above the center diff....so I guess in the end it probably doesn't matter
Just something else to upgrade!!
mriccucci
mriccucci's Avatar
04.13.2008, 08:45 PM
I know for fact that the transmissions in the e-maxx and t-maxx are interchangeable. You can swap the e-maxx transmission into a t-maxx with no problem.
xcntrk
xcntrk's Avatar
04.14.2008, 08:39 AM
^confirmed. The mounting placement and bolt pattern is the same; although the tranny’s are entirely different. Also the Tmaxx transmission is thicker and therefore uses a shorter front drive shaft from an emaxx unit.
Tmaxx BL Conversion
Hyper-7 Truggy
E-Slayer
