New BL Emaxx vid and problems
Looneybin
New BL Emaxx vid and problems - 04.09.2008, 02:42 PM
ok so i have been working on this emaxx project of mine and i have finnally gotten some runtime. but i also had some issues as well.
the truck runs hot, very hot. i don't have a temp gun but it shut its self down a couple of times during the run, after about 15min or so. both esc and motor are untouchable, batts are just a few degrees over ambient. i am running the new emaxx stock with a mm with bec and novaK cap, a fiego 8xl with full heat sink, and 2x 7 cell intellect 4200 batts. gearing is 22/68. whats the deal, i researched it and the setup was what several people recomended. does something sound wrong other than its a cheap setup. i ordered 16 and 18 tooth pinions but im still waiting on them. i have a extra mm sitting here, could I setup a good dual system or should i sell the two mambas and and buy a nicer esc? i don't need a stupid fast setup just something reliable and with decent runtime. i don't wish to go lipo either, at least right now. i have 2 sets of 7cell batts here that i would like to stick with.
rhylsadar
rhylsadar's Avatar
04.10.2008, 04:13 AM
hi
check if the tranny is really running free. buy a temp gun and try this 16T pinion first to see if this makes a huge difference. then you may check with the 18T.
a little fan on the esc wont be wrong either.
bye
rhylsadar
______________________
Exercitatio artem paravit
rhylsadar at youtube
aqwut
Brushless Heavy Weight....
aqwut's Avatar
04.10.2008, 12:42 PM
how's ur meshing?...sometimes the pinion rubs on the tranny cover..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
mkrusedc
NeuMaxx
mkrusedc's Avatar
04.10.2008, 12:58 PM
Check for binding in the drive train, Pinion/spur mesh, tranny, diffs etc. Everything should move freely and there should be the thickness of a sheet of paper between the pinion and the spur.
tashpop
04.10.2008, 01:52 PM
into the reading, i was going to suggest lipo but you fixed that. anyway, my thoughts are maybe you're dropping voltage and causing amp spikes even though your batts are staying cool.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
