2nd speed lock out
rc4x4nut
2nd speed lock out - 01.30.2005, 12:53 AM
i found this in a different forum and I thought I could share this to our members thanks to eric173
Okay guys, all done! Here are some pics. most are self explanatory. Here's a few tidbits of info. I made note of the way the bottom gear would rotate when the e-maxx moves forward. I was careful to screw the drive dog to the bottom gear so that the forward slack would be taken up. There won't be any stress on it this way, and no slack in the tranny! I used a 4mm tamiya shoulder bolt, nut, and washers, as a tranny plug where the shift lever use to exit the tranny. 3mm tamiya hardware replaces the screw pin that went thru the shifting fork. 6x12 plastic clod bushings ( 3 ) were used as spacers on the bottom shaft. ( 2 ) .5 mm washers and ( 9 ) 5x8 oilite bushings take up the slack on the top shaft and hold the case bearing in place. Believe it or not, those 9 oilites weigh far less than the small top gear I removed from the top shaft. Everything was spaced to the exact original specs as measured with my digital calipers. I found it funny I had just what I needed to make it come out right, Yaaa! on with the pics:
1. Here are all the parts scrubbed clean and ready to assemble.
2. Lower gear and drive dog screwed together with tamiya hardware.
3. From the back
4. side view.... sweet huh?
5. Tranny is much more simple now (as is the truck in general)
6. Again...
7. Again, another view...
8. Finished product showing off my freshly stripped and polished motor plate :)
Hopefully this is of some help to you guys.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
01.30.2005, 09:32 AM
I can't see the pictures! I certainly would like to see the inner workings of this. I am particularly interested in how he took up the slack inside the tranny, as I have not done that on mine.
rc4x4nut
01.30.2005, 09:41 AM
There you go Mike. They should work now.
RC-Monster Mike
Site Owner
01.30.2005, 10:08 AM
Thanks, Norbert. That is pretty much exactly what I did to mine, except I didn't screw the drive dog to the lower gear. I also used a brass spacer on the top and bottom shafts to take up the space (no bushings). Thanks for posting this. It should certainly help anyone interested in performing this mod.
rc4x4nut
01.30.2005, 12:26 PM
No problem Mike. I have been trying to find the supplies for me to do this but I cant find any. I tried my LHS and hardware store but no luck. Unfortunately I sold my tamiya kits.:mad:
Maybe we can setup a "How to" forums for stuff like this.
RC-Monster Mike
Site Owner
01.30.2005, 12:48 PM
It isn't necessary to use the Tamiya stuff. Basically, anything that fits the shaft will function as a spacer.
rc4x4nut
01.30.2005, 12:51 PM
Thanks Mike. I will look around some more.
