I need your input guys...
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
I need your input guys... - 09.01.2005, 01:02 PM
Hey guys,
It's me again. I know you're probably all getting fed up with me asking about BL setups for my Dagger, but at last I think I might actually be able to get some money to afford a system in the next few months (famous last words, lol!).
Anyway, as Mike and a few others of you know, I was planning on running a twin Feigao 8S/Warrior 9920 system. However I have come up with an idea for a system, which as far as I can work out would be more torquey, lighter and cheaper. I am having a custom chassis cut for me right now with a 16 cell capacity.
So I was thinking of using a pair of Feigao 16S (yes, 16S) motors. These would both be hooked up to a single Warrior 9920 controller, and be powered by 16 cells in series. Both motors together would still only give an amp draw of around 82A, and each would reach an RPM of around 42,000. Again, with both motors together I believe that they would be well within the Warrior's RPM limits. I am also considering possibly doing a similar setup using 14 cells and 14S motors.
So how well would this work? As far as I can work out, this would give much more torque (my main concern), be a little lighter and less expensive. And it wouldn't be any harder on the batteries than my original setup.
What do you think? Any input is really appreciated. Thanks!:D
