GorillaMaxx G1 tranny and RR Gen3 slipper unit
gumleguf
gumleguf's Avatar
Question GorillaMaxx G1 tranny and RR Gen3 slipper unit - 01.10.2012, 08:25 AM
I have this GorillaMaxx G1 tranny with GMaxx drivedog, strobe slipper, RCM iddler and FLM half-case:
The challenge is:
I want to use a Robinson Racing Gen 3 slipper unit and I want to be able to use the Traxxas 5151R center drive shafts.
I've seen various threads here and there showing off completed conversions but I haven't found a description detailed enough on how to do it. Hence my thread.
Here's what I have so far:
- Input shaft. Can I get the #5366 and which 18T gear should I use? Or should I buy the #3992 input shaft with gear already installed (downside is that it requires some heavy modding to the gear as far as I can see)?
- Output shaft. Do I need to change it or am already using the newer #3969 output shaft?
- Anything else? What did I miss?
Thanks in advance.
coolhandcountry
coolhandcountry's Avatar
01.10.2012, 04:44 PM
The center shafts will be determined more by your chassis.
gumleguf
gumleguf's Avatar
01.11.2012, 05:06 PM
Here was a great guide:
http://rc-monster.com/forum/showthread.php?t=11589
A different approach but also useful:
http://traxxas.com/forums/showthread...05-input-shaft
gumleguf
gumleguf's Avatar
01.12.2012, 08:57 AM
Right, so I ordered the #5366 Transmission Input Shaft Revo and the #3993 Input Shft Drive Gear. Should be all I need but I guess I'll find out.
gumleguf
gumleguf's Avatar
01.13.2012, 03:05 PM
Found out that the #3969 output shaft will *not* work in my G1 transmission (which uses a #3994 output shaft).
