New 35C hyperion G3 packs arrived...
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
New 35C hyperion G3 packs arrived... - 06.16.2009, 02:39 AM
I just got my Hyperion 3s 35C 4200mah packs in today.(5 days from Japan) I got a plug soldered on one, and halfway through the second, the soldering iron tip burned out. So there was no testing today.
Notice the side x side pic of them next to the 7s1p A123 pack, same size, little heavier, and twice the energy available, boyah. Can't wait to try them.
ID:	7270   Click image for larger version
ID:	7271   Click image for larger version
zeropointbug
Z-Pinch racer
06.16.2009, 02:43 AM
Oh, and the other three packs are the old stock packs I got for killer price, $90 each. 6s 4350mah/25C packs.
blueb8llz
06.16.2009, 03:00 AM
yea i saw those. i was tempted to buy those, but i chose the flightmax 5000 25c 6s instead.
if those hyperion litestorms were 5k, i woulda went with those.
do you have any of the flightmax by any chance. i would like to see a comparision to see if i made the right choice.
OZ-RUSTLER
OZ-RUSTLER's Avatar
06.16.2009, 02:58 AM
Look sweet. What burst rate to the 35C's have?
himalaya
himalaya's Avatar
06.16.2009, 04:46 AM
Wish you good luck on the old 25C 6S 4350mAh packs, pay sufficient attention to each cell's IR.
I believe I've shared my experience with you in another thread, exactly same pack from same vendor I think.
....What a Blue Sky....
zeropointbug
Z-Pinch racer
06.16.2009, 11:28 AM
Really? I don't recall you saying anything about them? Do you have these packs?
They are going to be used in a lawn mower, so only about 2.5C MAX discharge.
FG101C
06.16.2009, 12:26 PM
I've ran my G3 VX 35c 5s 4200 for over a week now and it is a very nice pack indeed.
zeropointbug
Z-Pinch racer
06.16.2009, 01:23 PM
Nice, did you get that 5s pack from Mike? I wonder if he will get some 6s and 3s packs in?
These packs are seriously not much more than A123 packs for the energy stored, ~22% higher cost per Wh over A123's. Also, if a last generation lipo that were taken care of would last between 150-200 cycles, they say these new packs last 4x cycle life... that's 600-800cycles, awesome. Now, all they need to do is make them intrinsically safe... but, they would need a different chemistry for that.
I yearn for the day when A123's next gen. battery comes to market... 200C/400C capable(basically 100% efficient), and 400+Wh/kg. The M1 cell holds ~100Wh/kg real world energy density... and these new lipo's hold between 140 - 150Wh/kg (depending on C rating/type).
zeropointbug
Z-Pinch racer
06.17.2009, 12:46 AM
So I did my first run with the 35C packs, and my first run with lipo packs period.
holy crap, holy crap, holy crap
I AM IN LOVE!
I swear if I never knew better I would of thought I was running a 1521 motor on my 7s2p A123 pack! Keep in mind this is the exact same setup as before, same gearing, whatnot. It is such a jump in performance over a 7s1p pack, like I can wheelie at almost any speed! It's insane! I am doing the same with less than 3/4 throttle vs. 100% throttle over the A123 pack, punch wise.
This is the first run, and Hyperion says it takes 5-10 cycles to reduce cell Ri, and still over the next 100 cycles as well (although to a lesser extent). Each 3s pack has a rated 0.004Ohm Ri, or 0.008Ohm for 6s... that is the same Ri as one M1 cell! I don't have my 720i charger in yet, so I used my power supply to charge them up using a 4.1v/cell CV voltage, so I am most likely not seeing the full performance of these bad boys.
Notice the packs voltage holding ability! 3.7v/cell @ 100 amps, yikes. That's 23C discharge! It barely gets below 22volts for bloodin sakes!
Name:	35C 4200mah 6s 45mph geared.jpg
himalaya
himalaya's Avatar
06.17.2009, 07:01 AM
Here it was, in another thread of yours:
http://www.rc-monster.com/forum/showthread.php?t=21129
http://www.rc-monster.com/forum/show...=16241&page=19
I am not too comfort to talk about something bad very loudly, sorry for that if I remind you too late.
Yes I have the same old VX 25C 4350-6S pack and found the above, just watch each cell's IR, good luck buddy.
PS: after that I switched to new G3 VX 35C 4200-6S pack, awesome batteries.
zeropointbug
Z-Pinch racer
06.17.2009, 11:27 AM
Has anyone else had trouble with this particular packs? I'm sure you just got a bad pack, which is bound to happen with lipo's. Again, unless of course it's happened to others, then I will be P!$$#D off.
The way you did the test to figure out the cells resistance is not very accurate however. Was the performance noticeable? How long have you had them? Have you thought about taking the pack apart and doing a high discharge test of each cell?
I am going to try and do a full eagletree run on the pack today if I have time. Yes man, these packs are awesome, but then again I'm sure any high end lipo pack would be killer going from a 7s A123 (2300mah). I might do a high speed run, geared for ~65mph.
Cheers
himalaya
himalaya's Avatar
06.18.2009, 01:11 AM
Cheers
They were BRAND NEW, from the same japanese shop.
Looks like I've written too much. Again, GOOD LUCK to you.
06.17.2009, 11:35 AM
I am the opposite of you ZPB. I started with lipo and after a while got some decent enerland based lipos. I have tried all of the cheap lipos as well. I then gave a123 a try and was a bit dissapointed. They were too heavy, bulky and just did not perform as I would have expected. Voltage drop was very noticeable with them even in a 2p config.
The are more robust and are supposed to last longer than lipo, I can appreciate that as being very desirable for alot of applications, especially cordless tools.
I like the fact you are testing those hyperion packs for the rest of us. I may have to break down and by new lipos! Time to sell off the current bunch I have... That will take a while...
MetalMan
MetalMan's Avatar
06.17.2009, 12:51 PM
This is the exact reason why my 40 A123 cells (all configured into packs of course) have been sitting. Lipo just feels better while driving. Well that and to get a suitable setup (2p, IMO) it's difficult to fit on the chassis.
zeropointbug
Z-Pinch racer
06.17.2009, 01:54 PM
Linc, yeah I agree with you completely, the throttle feel on A123's is a bit of a drop off, like it's not proportional, more like a curve that drops off at the top end. Even 2p like you said doesn't compare with these... it would take a 7s5p A123 pack to match the voltage holding ability of this pack, crazy. Sure you can get alot of 'power' out of a M1 cell, but it's not real world usable, especially for this application.
Metalman, you used to have a 5s2p 7XL setup correct? Funny, same as what I used to use... however, it does have more power than my 1512/3D with a 7s2p pack, call me crazy, but it did, hands down I could wheelie at almost any speed. Must have been a good setup to use the "C rating" aspect of the A123 cells, rather than it's voltage holding ability.
I will be back later with a good moderate power run with the Eagletree, and if I feel like it, I might shoot a short adult film... of the truck of course.
