Eagle tree data from FLM Savage and MMM before death
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
Eagle tree data from FLM Savage and MMM before death - 05.13.2008, 08:14 PM
So I thought I would post my eagle tree data from my short run before my MMM died. The Eagle Tree CDR file is attached. The graphs below show most of it. The second picture shows the biggest amp spike. The most concerning thing is the voltage drop. The pack is a brand new 4900mah 6s 20c neu energy pack with a MMM and Feigao 11XL 1516kv motor. You can see in the graph where the MMM died. It is doing what others have described, fan twitches when it is switched on and off, and castle link can't connect to it. Also the 65000 rpm spikes are just errors from the brushless motor rpm sensor.
tom255
tom255's Avatar
05.14.2008, 04:35 AM
Seems that MMM have BEC issues on 6S running. More and more MMM users experince similar problem. Thx god that I didnt ordered MMM yet I descided to wait until comes out Motor/ESC combo
Btw my MM do spikes over 118A and its rated 100A and all seems is ok, its must be internal BEC issue on MMM
crazyjr
crazyjr's Avatar
05.21.2008, 04:05 AM
Why wait, there will always be problems, no matter how you test it. remember the banana plug thing with the MM? They can't anticipate everything, Especially with the pressure to produce something. If i could swing it, I'd have three by now and had to send one back, oh well. Castle has the best support in the brushless industry, you should not fear buying a bad esc, they will take care of it
tom255
tom255's Avatar
05.21.2008, 08:12 AM
I understand your point, but I live in Europe and ship ESC overseas will cost money. Lets say if i Fry my MM i allready modded it and its not cowered by warranty so new ESC from Castle will cost $50 but another 50 i will pay for shipping maybe bit less :). Easyer buy another MM from www.b-p-p.com for $114 free shipping.
crazyjr
crazyjr's Avatar
05.21.2008, 04:39 PM
I see your point, didn't think about the overseas thing. Isn't there a distributer overseas that you could send it to for warranty purposes
Sammus
Sammus's Avatar
05.14.2008, 05:05 AM
The monster deaths I've read about that actually mentioned the batteries were all dead on 5s...
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
05.14.2008, 08:02 AM
Who knows but it doesn't really matter that I ordered early. At least I got to try it and I know castle will sort it out. Also don't plug your castle link into your esc for too long if it stops working like mine did. I just had mine plugged in for a while (computer was starting) and the castle link got really warm. This would suggest that plugging an external bec into it wouldn't be a good idea. Mine is going back in the morning.
xtremelimits285
E8ight T
xtremelimits285's Avatar
05.14.2008, 10:22 AM
im always start Low with my cars
WHEN MY MMM COMES,
ill try my 3s 8000 pack, low(25mph gearing) an set every setting on cc castle link soft ware to the lowest settings,ei. lowwest timming, 100% curent limiter, an LVC to 9.6v (for 3s)..
if all goes well ill try 5s(same settings) an see what happens....
better to be on the safe side....
Gary Antonietti #9
Losi 8ight T - Monster Mamba - Neu 1515 1y - MaxxAmps 3s/4s/5s 8000mah - Futaba 2.4GHz Tx/Rx 6EX - Futaba S9351 servo - 15/46t gearing
FTT3 -Mamba Max - 2s 8000mah
  Send a message via MSN to xtremelimits285
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
05.14.2008, 10:31 PM
WHEN MY MMM COMES,
I really don't think that would have helped. The graph shows that I hadn't pushed the esc that hard going by the specs. The battery on the other hand was being pushed. I'm guessing a bad component failed but we will know in 2 or 3 weeks as my esc is on it's way back to the USA already.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
06.04.2008, 07:09 AM
So I ran the Mamba Monster again in my savage after getting it back from Castle for repair. Guess where it is headed in the morning?
Anyway here is the pretty graph of the second run that lasted a hole minute and a half.
So am I the only lucky one to break this esc twice? Exactly the same symptoms as last time.
Sammus
Sammus's Avatar
06.04.2008, 09:10 AM
Dang, thats some bad luck dude... Castle mustn't be happy about all this.. And to think the years delay meant to everyone that it would be thoroughly tested.
People can say first releases always have problems all they want, this does seem to be a little more than that though...
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
06.04.2008, 05:28 PM
And it sucks that I am having bad luck when I'm on the other side of the world. I hope I don't have a bad servo or anything like that causing this problem.
