Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
any motor mounts fit these dimenisons?
rootar
rootar's Avatar
any motor mounts fit these dimenisons? - 05.16.2008, 06:15 PM
mike does any of your motor moutns fit these dimensions, sorry i dont have a cailper handy so these were done with a 6inch calibrated rule.
ok the over all height is 1.875", the distance between bottom bulks mount holes (center to center) is .9375", center to center of the top holes is .875" (this dimension is no big deal as i can make a new brace to match the holes), the center diff uses a 8x16 bearing and its center is .875 inches from the bottom, it uses a spacer underneath both front and rear bulks that is 1/8th inch thick to raise it enough for the 54t spur, if you have mount the right height but center hole is an 1/8 inch high i could make a space to seton top of your mount........
let me know something, you you dont have one already i wont trouble you with maching one and ill just make my own, but if you have one i figured id just save my time and buy it from you.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
06.04.2008, 11:48 AM
The easiest way would be to send me a center diff bulkhead to compare to others - not sure what vehicle this is for(GS storm as in your sig.?), but we make a lot of mounts, and many fit several vehicles. It has been a couple weeks since you posted this, so perhaps you found the proper one already?
