Balancing Taps.
Mike.L
Mike.L's Avatar
Balancing Taps. - 09.30.2008, 04:39 PM
hello all, im a little confused here, im planing on using zippy lipos here. They come with a jst-xh taps. I want to balence using a flightpower balancer. So if i buy these nessesities that i link for you it would work correct?
From flightpower balancer to this http://www.maxamps.com/TP4S-HYP-Adapter.htm
then that tap goes to this http://www.maxamps.com/HYP-MULTI-ALIGN.htm
then from the conversion board i connect the lipo tap and charge????
Can Someone clarify this for me.
Anyone that uses zippy lipos can you tell me how and what you use to balance. Thanks mike.
  Send a message via MSN to Mike.L
Mike.L
Mike.L's Avatar
10.01.2008, 03:18 PM
anyone can tell me please???
blueb8llz
10.09.2008, 08:41 PM
it looks like you got the right idea. my charger come built with a balancer already.
i use a hyperion 0606i charger with the lba10-xh balance adapter to charge my zippys.
10.09.2008, 08:45 PM
Jst taps are the same as the Align taps which is what I use with my Equinox ballancer. All you need is the adapter to go from Jst to Fp taps.
