Monster and Castle Link 3.05
Rcaddict
Monster and Castle Link 3.05 - 05.27.2008, 08:43 AM
Has anyone else had a problem with Castle Link 3.05 and the Monster? The ESC worked great if I reset everything to factory default, but if I made any changes using 3.05 and updated the controller, the motor would not run. I updated to Castle Link 3.051 and everything works great now.
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
05.27.2008, 10:28 AM
That was the reason for the update to 3.051.
redshift
RC-Monster Square Tube
redshift's Avatar
12.08.2008, 06:13 PM
Best thread I could find to ask the pros....... how do I use Castle Link to recognize one MM and also one MMM?
Pretty sure it can be done?
12.08.2008, 06:24 PM
Not sure what you mean - the MMM uses the USB adapter and the MM does not.
Are you running Vista64 in which case I've found castlelink works with the MMM but not with the MM.
I have to dual boot to XP or use wifes machine...
redshift
redshift's Avatar
12.08.2008, 07:15 PM
Ok a buddy (who has no computer) just got a Monster, I already had 3.051 installed for my Max, from what you say I can't adjust both under the same CL install?
How can I dual boot as you said?
12.08.2008, 07:19 PM
You can adjust both but it will warn about a higher version of firmware just press ignore.
Personally I would upgrade to 3.12 castle link - Supposed to be much better for both controllers and save blowing the MMM.
redshift
redshift's Avatar
12.08.2008, 07:46 PM
Wow I've been sleeping in class again.
I now have 3.12 thanks, one last thing before I connect either the MM or MMM, would I simply save the MMM settings as a separate saved file, then still have my priority settings for my MM just by going to the CL mainpage?
12.08.2008, 07:49 PM
It will always read the settings on teh controller so never wipes anything out when swapping between controllers.
You could when you get happy with a setup save down a MM and a MMM so you can always go back to a setting you like.
redshift
redshift's Avatar
12.08.2008, 07:55 PM
Great to know, thank you.
Hate to do this, one more quickie- will the v3.12 automatically update my MM firmware, or give me a prompt?
redshift
redshift's Avatar
12.08.2008, 08:19 PM
Nm, I have a prompt.
Big help, much appreciated :)
12.08.2008, 09:42 PM
np..
