Losi mini late-model/slider gear size?
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
Losi mini late-model/slider gear size? - 10.26.2008, 03:13 PM
I race a losi mini late-model at my lhs's carpet track. It's a stock class, but I have managed to sneak in a Mamba25/5400kv setup. I'm still the slow one in the expert class, got moved up from advance. My problem is finding the right pinion gear for the motor. The pinions that come with the car are 14,15,16 but are plastic and just pess on, the stock motor has a knurled shaft. Well after blowing 3 stock motors and removing the 16t pinion several times it will not hold on my cc motor. My question is what pitch are these gears? They are the same between the mini-t, slider, late-model, m-lst I beleive so if anyone has one of these and can enlighten me it would be appreciated, otherwise I have to try CA or loctite to hold the 16t on. The 15t is leaving me a few laps behind!
Snowman 78
5,280 feet above sea level
Snowman 78's Avatar
10.26.2008, 08:02 PM
The motor shaft for the Mamba motor should be 2mm, so any 2mm pinion should work. I use the metal one's for the RC18
http://www3.towerhobbies.com/cgi-bin...ION+&search=Go
Brushless Rustler
AX10
Venom Creeper
Slash 2WD
Slash 4WD
10.26.2008, 08:16 PM
Robinson racing also make pinions that will work, 12t all the way to 25t IIRC.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
10.26.2008, 10:06 PM
so they are .5mod?
