Battery swap/pit stop.
CrazyCooydog
Battery swap/pit stop. - 11.07.2008, 11:56 PM
Would it realy be nessesary to havea "quick" change battery system?
I can see how this would have been a good thing last year, but looking to the future I'm seeing theres not buch need for such a system. I meen when all Electrics start running together why would you need a quick change system
As most mains would likely be only 15-20 mins, which we can all ready do.
What do ya'll think?
rootar
rootar's Avatar
11.08.2008, 01:26 AM
yea but the 30 minutes long mains are alot of fun imo, but yes if there were enough brushless' to run a class seperate from the nitros id guess the mains would be 15 minutes.
CrazyCooydog
11.08.2008, 09:54 AM
I love the 30min mains..I realy think this helps seperate the drivers from the bashers
Or I guess there is endouro's.
bring it on.
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
11.08.2008, 01:54 PM
maybe like a lexan hinge battery compartment door......and a hard cased lipo with the female bullet inside the case.....and the esc plugs integrated into the battery tray so to plug the battery in you just have to snap it back into the tray....IDK...that would be something pretty cool esp. if anyone would compete in an hour long main like maybe.. The Worlds...??? Imagine a brushless buggy winning the worlds....now THAT would be the start of the revolution...hmmm
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
auto2
11.08.2008, 04:26 PM
if it is an all electric race run for as long as u like. just have yellow flags and everyone pits at the same time.
11.08.2008, 10:47 PM
Not a bad idea. If the race was run w/15-20 min. mains., a mandatory stop for a batt. change, restart in the same order, it would work. As long as the transponders are being used, there could be more than 1 stop.
CrazyCooydog
11.08.2008, 05:29 PM
Kind'a sorta!
this system maight be a bit tight for a buggy. I guess it would work if you used the shorter packs like the MA,track power,or zippy's
I couldn't imagine the organizers alowing a E to race at the worlds.. But it sure would be cool.
Tempted
RCM is smarter than me....
Tempted's Avatar
11.08.2008, 05:49 PM
I can figure this out very easily. Use multiple bodies and attach the pack to the body itself so all you would do is unclip the body and clip a new one on. Just as fast, maybe faster than refueling a nitro.
The answer is no. And yes, mine is faster.
t-maxxracer32
t-maxxracer32's Avatar
11.08.2008, 05:56 PM
that would be pretty good ^^ as long as you found a sturdy way to keep the lipo on the body
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
11.08.2008, 06:20 PM
or if the lipo is already in a hard protective case just cut out the section of the body that is over the battery tray......so now all you would need to do is unplug the battery and not have to mess/fumble around with those tiny body clips....
Losi SCTE
MMP/1410 3800kv
Dx3s
Tempted
Tempted's Avatar
11.08.2008, 07:39 PM
You still have clips that hold the battery in but they are much smaller and more difficult to get to. And in most cases to be able to quickly get the pack in and out you would have to cut a huge hole in the body, much too large to run in an event.
CrazyCooydog
11.09.2008, 01:32 AM
Sorry guy's but I posted a poll here...
http://www.rc-monster.com/forum/showthread.php?t=16435
I surely would not strap one of my $250 lipos to my lexan body and hope to use it again.
A very awsome system does exsist.
Tempted
Tempted's Avatar
11.09.2008, 01:54 AM
I wouldn't pay $250 for a LiPo . What difference would it be bolting a pack to the body verses strapping it in with velcro? Whens the last time you saw a body fly off during a race? Its the only reasonable solution for a problem that really doesn't exist. The only other quick change option would be to load the batteries via a clip through the bottom of the vehicle. Similar to how a pistol holds its clip in. The problem is reliability. It may drop the pack during a race and that wouldn't be very good.
t-maxxracer32
11.09.2008, 02:31 AM
i think someone said this already but it would be easy if there was some type of bolt in battery where you slide it in and it locks into place. 2 prongs (positive negative) go into 2 holes (post & negative) once you slide it in it lock and at the same time it will get power.
make sence?
11.09.2008, 02:52 AM
Ok, I have a few ideas.
First the body will have to be made differently to cover the electonics but leave a portion of the chassis exposed. The lipo would have a hard case, with some sort of female bullet connectors, most likely at each end. A small base, attached to the chassis would have male bullet connectors pointing upward. Use 4 steel round posts on the base, one at each corner that will go thru a corresponding hole in the hard case. That would keep the pack in place front-to-back and side-to-side. A special over center style latch would hold the pack to the chassis and when unlatched would lift the pack off the chassis to aid in quick removal.
I have the latch mentally designed. The molded hardcase would require a bit of design, but could be a 2 piece item that just bolts together. Maybe some foam inside for impact assistance? With careful use of materials weight could be kept down, maybe not as light as a conventional tray though...
