Slash+mm7700
Thunderbruiser
Thunderbruiser's Avatar
Slash+mm7700 - 11.09.2008, 01:41 PM
I like the power that the 7700 has and was wondering if you think it'd be ok temp wise in a slash geared 17/90(45 theoretical top speed)(56980 rpm) and running 2s lipo
or would that be pushing it?
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
  Send a message via Yahoo to Thunderbruiser Send a message via AIM to Thunderbruiser
Raze ST Truggy
11.09.2008, 02:04 PM
I don't have a slash, but a rustler and have ran the mm with a c4 7700kv motor on 2S lipo. I think it was geared 19/90 or 20/90 and the temps are great. The lipo is ~80-85f, was ~110-120f, and the motor was ~120 on the can depending how hard I was on it. But in my opinion (which is pretty limited) I think it's a very efficient setup. I've even got the FLM aluminum chassis that makes my rustler hearier then the slask I think.
-Brian
I Trust Tyler
I Trust Tyler's Avatar
11.09.2008, 10:41 PM
I have a slash, i run mm5700 on 7-8 cell gp3300's stock geared it doesn't get hot unless i beat on it hard for a few packs straight. I wouldn't run the 7700 unless thats all i had, i think a 5700 or a lower kv motor would be better even though the slash is pretty light.
Thunderbruiser
11.10.2008, 03:53 PM
i assume it should be ok cause in my st I ran a 21/87 and it got pretty warm but never enough to melt anything...so I am thinking geared more conservative like 17-16/90 should be fine...Idon't want the 5700 but I might buy it not sure
garage:
I Trust Tyler
11.12.2008, 06:00 PM
I was just running my stock geared slash(18/86??) on 2s lipo 8000 with the mm + 5700 and the motor got toasty after about 20mins, and its like 50 degrees outside. Just figured i throw out some useful info, i really wanna get a velineon 3500 or mm4600 with 3s lipo, but the speed of the 2s setup is plenty for offroad. let me know how your setup is, im curious. Peace!
Thunderbruiser
11.13.2008, 02:14 AM
well i ran the 2s lipo(8000) in my old st geared 21/87 and it didn't get too warm now I did run the mm 7700 that i used to own on my slash with a 8 cell pack and it got way too hot batts were 160 range and would only run about 5 minutes...according to the gearing chart I had a 70mph estimated ratio(this was running stock gear ratio)
but i think i am gonna run the mamba max esc and try one of the hobby wing motors:
http://www.hobbycity.com/hobbycity/s...idProduct=7195 for $41 bucks and run a 2s/ 3s setup and see how it goes
garage:
