Team Losi LST XXL Monster Truck RTR
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
Team Losi LST XXL Monster Truck RTR - 11.20.2008, 05:11 PM
The nitro-powered 1/8-scale LST XXL RTR Monster Truck proves that bigger is always better. The LST XXL features parts and design elements that make it more durable than you could possibly imagine. The LST XXL features an extended wheelbase and a longer chassis which provides improved handling and stability, making for a better ride and easier operation.
The installed Losi 454 Engine is designed to produce unbeatable low end torque as well as high-rev horsepower for insane top speeds. Dyno tuned and ported for the highest level of power from the first startup, the 454 big block engine can pull the LST XXL from a dead stop up to speeds approaching 50 mph without a hiccup. The 454 Engine also offers the convenience of a combo Pull Start/Spin-Start backplate, with a hand held, push-button Spin-Start unit included.
Spektrum’s DX3S 3-Channel sport radio system with 2.4GHz DSM technology lets LST XXL drivers and racers experience the next level in precise control, while offering the added benefit of integrated telemetry. The addition of integrated telemetry provides users with real-time information such as head temperature, speed, RPM and voltage information. The LST XXL includes a NiMH receiver battery, making it easy to fire up the engine and get started.
The 2-speed transmission in the LST XXL offers optimized gear ratios for the perfect combination of low-end, turf-shredding torque and high-rev, high-speed horsepower. Additionally, the transmission offers reverse, making maneuvering easier. The 3-shoe aluminum clutch design features high-strength steel clutch springs to ensure that when you grab the throttle, the clutch is there to get the LST XXL moving in a hurry.
Armed with high-torque motors and metal gears, the dual steering servos on the LST XXL can move the oversized Force wheels and tires with outstanding precision. Twin servos offer double the torque, so you can point the LST XXL wherever you want it to go and expect it to respond instantly.
The molded suspension components on the LST XXL are formed from the same high-impact polymers and compounds used on Losi’s 1/8-scale race platforms, offering unmatched durability and precision. The front, rear and center CV driveshafts provide efficient drivetrain power, and the differentials on the LST XXL are built with metal gears to handle serious off-road abuse.
Tackling any terrain requires some intense traction, and the LST XXL delivers with custom chrome Force wheels and purpose-designed ATX tires. The custom look of the chrome wheels stays uninterrupted thanks to removable chrome caps to cover the wheel nuts for added realism. Losi’s ATX tires let the LST XXL take on anything in its path without hesitation, rolling over obstacles that would stop other trucks in their tracks.
Features
Extended chassis offers increased handling and stability on the roughest terrain
Installed Losi 454 Engine offers the convenience of a dual Pull Start/Spin-Start backplate, with the hand-held spin-start unit included
Spektrum DX3S 3-Channel 2.4GHz DSM radio system with integrated telemetry
Forward & reverse 2-speed transmission features optimized gear ratios for low-end torque and high-rev horsepower
Ultra-durable molded suspension components offer unmatched durability and precision
Twin, high-torque steering servos offer double the torque and provide instant response
420 Series Force wheels and ATX tires take on anything in their path without hesitation
Complete ball bearings, even on the steering, for smooth and efficient operation
All steel gears in the transmission for power and durability
3-Shoe clutch with all-aluminum shoes for effective power transfer
Metal gear differentials built to handle serious off-road abuse
CV Driveshafts front, rear & center for more efficient drivetrain power
Specifications
Type: 4WD Monster Truck
Scale: 1/8
Length: 23 in (589mm)
Width: 18.5 in (470mm)
Wheelbase: 15.3 in (391mm)
Weight: 13 lbs (5897g)
Motor or Engine: 454 Nitro Engine
Radio: Spektrum™ DX3S with built in telemetry
Kit/RTR: RTR
You will need...
Nitro Fuel
Glow Driver
7.2V Battery Pack for Spin-Start Unit
Battery Charger for Included 6V 900mAh NiMH Receiver Battery Pack
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
