Beadlock wheels for crt.5? -
11.17.2008, 07:07 PM
Does anyone make a 2.2 truck wheel, 12mm hex, that will fit the CRT.5?
E-8ight - Tekin RX8 2000kv/4S
11.17.2008, 07:22 PM
Axial does
11.17.2008, 07:35 PM
Originally Posted by BlackedOutREVO
Axial does
They do? I looked for some earlier this month and was unable to find any...guessed I should have asked here first...
11.17.2008, 07:37 PM
I believe I found some.... http://www3.towerhobbies.com/cgi-bin...&I=LXRGT3&P=ML
If I had seen these before, I would have tried them.
11.17.2008, 08:00 PM
11.17.2008, 08:23 PM
Originally Posted by hemicuda11
The first set you have there won't fit...I tried them, the hex is right, but the mounting hole is to big.
The second set looks do able though.
11.17.2008, 08:25 PM
Cool, the second set looks lighter.
11.17.2008, 08:29 PM
The first set is v/heavy...almost too heavy for the crt.5
11.17.2008, 08:50 PM
Most beadlock wheels are narrower than std 2.2 truck tires, sometimes much narrower. Just thought you would like to know that...
11.17.2008, 09:02 PM
I'd seen those and like the look of the Prolines, but the widest i've seen are only 1.4" wide and stock 2.2 truck wheels are 2.0" wide. Anyone know of a 2.2" dia x 2.0" width beadlock wheel? And, if so can they handle a tire on 3S? I do tape the inside of my tires which helps a lot on keeping them on the rims, and actually makes the car handle better.
11.17.2008, 11:06 PM
Did someone say beadlocks, I have friend that makes these.
RC-Monster RC8T
11.17.2008, 11:17 PM
Tires suck but the rim holds well!!! That was truly a pizza cutter!
11.17.2008, 11:19 PM
 Yep the tires suck, but rims are the stank !!
11.18.2008, 12:02 AM
Where would one find said stanky rims?
Linear Mode
