looking for front upper Turnbuckles 3.5x24mm
chadr
looking for front upper Turnbuckles 3.5x24mm - 12.27.2008, 12:42 AM
First part on my crt.5 to break. Anyone have old ones to get rid of after changing to titanium or something else. If not, I'll order some up on ebay. What other parts should I get as spares since my lhs doesn't stock anything?
thanks - chad
GO-RIDE.com
12.27.2008, 04:51 PM
The front upper arm turnbuckle is the weakest part on the crt.5, and the Ti ones are even weaker. If you can't get them locally, then try RCPlanet, Amainhobbies, Nitrohouse, or Impacktrc. They are all good, stock crt.5 parts and that part is only $4. I wouldn't bother with the hassles of ebay.
As for other parts if you drive hard:
Lower Arms
Upper Arm outer section
Steering Rack
Front Hubs & Knuckles
If you want to cut down on the upper turnbuckle from breaking then completely thread the turnbuckle into the upper arm parts and move the outer eyelet to the inner hole on the hub. You may have to back the turnbuckles out 1 turn to get the camber you want, but they will be a lot stronger.
E-8ight - Tekin RX8 2000kv/4S
e-rev project
12.28.2008, 12:01 AM
i actually seem to have good luck with ebay & buying small parts, it's usually still cheaper than my lhs or .com's w/shipping. just buy from the bigger sellers
