Upper hole in tranny case not centered (motor side)
standard_63
standard_63's Avatar
Upper hole in tranny case not centered (motor side) - 07.31.2006, 01:14 AM
I was just taking my aluminum tranny case out to finally install it into my 1/2 case setup, and I noticed the upper hole is not drilled perfectly center. I don't know if it's the hole, or the lip around the hole for the bearing that's not even, but it looks a bit funny. Anyone else get a case with the upper bearing seat off center like this? Will there be any fitment problems with my upper shaft if I stick it in like this? I remember some people complaing their 1/2 case and aluminum case didn't match up smoothly. Is there a newer batch that might not have the defect?:032: Picture is kinda blurry cuz it's still in the packaging -- I might want to send it back...
Please tell me that's not smoke I see!
go4gold
mod emaxx
go4gold's Avatar
07.31.2006, 02:12 AM
I see what you mean. If you're lucky, it's the hole and not the counterbore (lip around the hole).If it's just the hole then the bearing will be in the right spot allowing the shaft to be positioned correctly for assembly. That's about all that I have since I'm still running the stock tranny. good luck.
So many toys and so little time
neweuser
neweuser's Avatar
07.31.2006, 02:43 PM
go4gold is right, it's not the hole that centers your shaft, it's the bearings, so if they are aligned properly still you shouldn't have a problem. But i would still send it back because it should be proper. They can't fix the issue unless they know about it as well. If you still have the stock case, use that until you get your replacement. There is my 2 cents!
Darren
07.31.2006, 05:45 PM
I have had a problem with every FLM part i've bought. Not touching them again.
Gustav
Gustav's Avatar
08.01.2006, 03:25 AM
I'm pretty sure mine's like that aswell,but as has been said it's not a problem,the hole just has to be big enough to allow the top shaft through
.The problem with mine,and others aswell,is that hole on the other side of the case isn't milled deep enough so it compresses the top shaft bearings and causes binding when you tighten the case.The solution is to either grind some off the end of the top gear or if you have access to a mill then run an endmill in there to make it deeper.Hopefully yours will be OK though.Other thing is, it may need some grinding inside the case to clear the idler gears(mine did)
squeeforever
squeeforever's Avatar
08.01.2006, 08:57 AM
You just have to understand, with such a small company such as FLM, things like this happen.
neweuser
neweuser's Avatar
08.01.2006, 08:58 AM
FLM has good product. I'm sure if you contact them, or let them know, they willtake care of it. Or, see what Mike can do.
Serum
Serum's Avatar
08.04.2006, 10:19 AM
that is a problem with the FLM cases, thought it's not much of a problem, it's just the outer hole isn't centered.
I wonder why on earth they didn't changed it. I had mine when it just came out and i reported it too. it's not that hard to open a drawing and adjust it a bit... :p
giftacrylic
RC-Monster G-Maxx
giftacrylic's Avatar
08.13.2006, 07:25 AM
I am considering buying the FLM half-case. Has FLM fixed this hole alignment problem?
coolhandcountry
coolhandcountry's Avatar
08.13.2006, 08:24 AM
I think my hole looked off but when put together it lined up like new.
They could slow the machining process down to be more percise.
We may not get the case for 90 bucks then. They would have
a price like the rest. 150 or more. If ue made a case it would
be more percise but the price would be 300. I don't notice the
hole being off at 60 mph and the body on it.
Peace!
Country
Help support the
Rc-Monster
Buy here
Serum
Serum's Avatar
08.13.2006, 08:57 AM
LOL leroy..
here are a few pics of the tranny.
You can choose between the GPM (CRAPCOUGHCOUGHMOLDEDCOUGH) or the CNC machined FLM.. I would take an FLM over the GPM anyday.
standard_63
08.14.2006, 05:13 PM
If it works ok and only looks funny, I don't care much. If were bad enough to not fit though, I asked so that someone could warn me before I took the old one apart that it might not fit. If it fits, no big deal. If it doesn't fit, I'm a comin' after y'all!
Procharged5.0
Procharged5.0's Avatar
08.14.2006, 08:23 PM
I have not noticed that problem but I have not yet assembled mine. I was waiting on a replacement idler gear shaft support. The one that came with my trans was bored incorrectly and the shafts did not fit. Now that the replacement part is here I'll check it out.
jocktheglide
08.14.2006, 09:03 PM
wow nice polish man...just curious if you do your own polishing I have some stuff to polish and wondering how much it would cost...
Procharged5.0
08.15.2006, 03:04 PM
Yes, I polish all my own stuff. Right now I don't have time to polish anything, LOL I'm still trying to finish polishing my chassis which is partially done but on hold until I sort out the trans mounting issues. I may have to send in this chassis for a replacement (there goes all the hard work!).
Hopefully I'll be able to help a few of you guys out and polish a limited number of items. Doing the FLM transcase to "mirror" polished finish takes about 6 hours. I'm doing it because I've always wanted a Polished Supermaxx Truck. It may be a bit of a maintenance headache to keep up but I'll give it a go. I also have a special clear coat designed for polished metals. I may or may not use it. With all the flying debris it might chip the clear which would be worse than dulling the metal.
Finally, I'll post some pics, but most of my pics are on my laptop pc. Next time I fire it up I'll post some pics.
ID:	1546   Click image for larger version
ID:	1543   Click image for larger version
Name:	Smaxx a web.JPG
Name:	Smaxx b web.JPG
