Spektrum RX question
KaztheMinotaur
KaztheMinotaur's Avatar
Spektrum RX question - 02.18.2009, 03:18 AM
I have a question about Spektrum receivers that use a binding plug, like the SR300. After binding do you power it through the bind port if you are running 3servos?
02.18.2009, 06:09 AM
i presume you are having dual steering servos - in which case you run a y splitter off of the steering channel.
you can use the bind slot for power but not for a servo
KaztheMinotaur
02.18.2009, 06:55 AM
2 servos and a kill switch on Ch. 3. As long as I can power it through the bind port I'll be good.
02.18.2009, 07:05 AM
should be fine the bind port works by grounding the signal line...
jhautz
jhautz's Avatar
02.18.2009, 04:22 PM
Yep. I power my transponder on the 3rd channel and power thru the bind port. Works just like any battery input port on a conventiona Rx.
to make it...
or break it...
Silent...But Deadly
