BL E-zilla , BK 7020/9L possible?
VWT4
BL E-zilla , BK 7020/9L possible? - 12.01.2005, 05:30 AM
Hello,
I own an HB E-zilla and I want to go brushless...
It is stock with 13cm diameter tires, 66T spur and 20T pinion (1/8 shaft), weights 4.3 kg.
Will work this set-up?: BK 7020 (only 70 Amps) and a Feigao 9L.
The batteries are LRP 3.000mA 6 Paks and LRP 3.300mA 7 cells packs.
I have a motor heatsink/fan . Should I install a ESC fan, too?
regards.
VWT4
12.01.2005, 07:42 AM
I forget,,,
Gear ratio is 16.75:1 with the stock 20T pinion.
coolhandcountry
coolhandcountry's Avatar
12.01.2005, 09:24 AM
Welcome to the forum there vwt4.
I would not run this setup. The 9l is fine but I am pretty sure you going to have thermal problems with esc. If you do I would definitely put the fan on esc. You going to have to change the gear ratio as well.
VWT4
12.01.2005, 10:07 AM
Do you think a 19,71:1 gear ratio (with 17t pinion)would be better?
And a 9XL?
thnks.
Serum
Serum's Avatar
12.01.2005, 12:54 PM
That would be better for sure. what speed do you wish to reach?
VWT4
12.01.2005, 01:03 PM
50km/h would be great!
Then a near 20:1 ratio and a 9XL is a good idea?
Serum
Serum's Avatar
12.01.2005, 01:23 PM
With the gearing you have got in mind, it would do 55 km/h.. I would use a 9920 anyway. the XL series can take some serious power for sure.
rchippie
rchippie's Avatar
12.01.2005, 02:05 PM
Is there much of a diference between a savage chassis & a Ezilla chassis ?. Besides all the nitro stuff.
REAL MEN RUN BRUSHLESS
Serum
Serum's Avatar
12.01.2005, 02:09 PM
yeah, i don't like the e-zilla...
No, serious, they are rather alike. not the same, they just look alike
VWT4
12.01.2005, 02:13 PM
Both wears TVPs but the E-zilla is a little smaller.
rchippie
rchippie's Avatar
12.01.2005, 02:14 PM
So would it be better to convert a savage oe use the Ezilla chassis ?.
Serum
Serum's Avatar
12.01.2005, 02:18 PM
savage is proven tough and has got more nice hopups available!
VWT4
12.01.2005, 02:26 PM
Yes, but the E-zilla is in the beginning...
In a few months will be lots of afftermarket parts.
Gustav
Gustav's Avatar
12.01.2005, 02:29 PM
The e-zilla is 1/10 scale though,i think the stock tyres are more like 2.2" sized?
I'd like to know what the diffs are like on this truck.
In this link:http://www.rcuniverse.com/forum/m_30..._2/key_/tm.htm ,if you scroll down to a pic of it next to what looks like a lightning GT you can see how small it is.I'm not sure i'd want to put an XL motor in it.
Serum
Serum's Avatar
12.01.2005, 02:37 PM
I don't like it in general, it's just a cheap ripoff imo, and it is alot like the conversions we did in the beginning with our savage, i don't like the battery packs sticking out under that angle, like they do..
it just doesn't tinker my bells..
