larger hub carriers for emaxx
maximum
maximum's Avatar
larger hub carriers for emaxx - 12.30.2005, 11:34 PM
I haven't had a problem on the few runs i've had with my new emaxx exept for the right front wheel nut coming off ( luckily i was going slow and was able to find it ) but was wondering if what i heard was correct about the bearings being undersized and if it would cause a serious enough problem to buy larger carriers? thanks.:C:
E-Traxxer
12.31.2005, 03:00 AM
The reason the nut is coming off is because the axle that it is screwed on spins and the nut can slip and un-screw itself out, it has nothing to do with the bearing or hub carriers. Use some blue loctite and that should fix the problem.
crazyjr
crazyjr's Avatar
12.31.2005, 10:51 AM
I had the same problem with the right rear on my revo and blue locktite fixed it
