MMM mounting
Marvin
THE Paranoid Android
Marvin's Avatar
MMM mounting - 03.07.2009, 05:30 PM
I've just got my MMM through the post (thanks George16) and I know mounting them is often a problem. I was thinking that, why don't you just remove the bottom of the case, drill 4 holes in the corners ~2.5mm and tap them with an M3 tap. You could use thin nuts to secure the screws as there is plenty of space inside. Then just screw it to wherever it needs to go with a bit of servo tape just in case. Don't know if this has been tried before, but I'd of thought that this would be the best way to mount it securely.
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
George16
Supermaxx
George16's Avatar
03.07.2009, 06:18 PM
I think it was tried before but be very careful when opening the ESC. Castle actually have a "How to open" procedure to lower the risk of damaging something. Even with this type of mod, you still have the chance of popping it off through the tabs but you can prevent it by taping the bottom and top case together.
I have my MMMs held by indusrial strength velcro with a ziptie and it works really well.
Glad to hear you received the ESC.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
03.07.2009, 06:53 PM
Sounds like an idea. Might be tricky, but could work well.
I gotta admit though...my MMM is just velcro'd down using industrial velcro, and after quite a few hard crashes, rolls and landings, the case isn't showing any signs of wanting to come apart. Must just be me, but mine seems very solidly held together by the clips. Everyone else seems to have problems with the case coming apart, but no problems here.
Marvin
Marvin's Avatar
03.08.2009, 08:49 AM
No, I mean holding it to the car - not too worried about the case coming apart - going to have a cable tie (zip tie) around it to stop that. The only reason I thought of it is, as a racer, I don't like anything not screwed down, and that is what always bothered me about electric racing - one big crash, and out go all your expensive electrics.
warbunny1
03.08.2009, 10:16 AM
I used a revo steering link with a piece of fuel tubing in the center, across the middle of the MMM. Then I ran longer screws down the sides into the chassis. I was using the Losi kit on an 8ight.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
03.08.2009, 10:22 AM
I have mine zip tied to an aluminum plate that is screwed to the chassis, hasn't moved! However when Traxxas releases there hold down for the Monster I WILL HAVE ONE!!!
Marvin
Marvin's Avatar
03.08.2009, 10:46 AM
So you don't reckon there's much point in screwing it down the way I suggested? Just get some good double sided tape and a zip tie or two, and that'll be alright - ok, guess it is also easier than drilling holes and stuff into the Mamba.
Cheers guys
Simon
phildogg
phildogg's Avatar
03.08.2009, 10:53 AM
I also have a plate screwed to the revo and then esc held with velcro and a ziptie. seems secure enough for me.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
Marvin
Marvin's Avatar
03.09.2009, 02:43 PM
That's pretty much what I've done, I'll put a build thread with piccies up soon. Getting Mike's bits for it this Friday, after I've paid the extortionate customs charges. Already got 2 4S Flightpower Lipos 4350mAh 25C, a 5S Tornado 3700 mAh Lipo 22C, and a 6S Flightpower 3200mAh 20C (may sell this one though...). I've also got my MMM - I hadn't realised just how big it was! I've never seen such a massive speedo! How big must those Hobbywing Speedos be!?!
rootar
rootar's Avatar
03.09.2009, 08:31 PM
here is my mount i use....velcro underneath and a clamp on top works awesome and easy to remove the MMM and no use of zipties...
Marvin
Marvin's Avatar
03.10.2009, 12:18 PM
That is very nicely done...
I just don't have enough space on my chassis to do that...
big greg
03.10.2009, 04:02 PM
i am putting small zip strips through the small openings in the side, right ove the heatsink, double sided tape on the bottem, and a big one on top, ive seen like 4 come loose and rip apart at my track, the case DOES come open, ive seen it!
