click when braking hard!
phildogg
phildogg's Avatar
click when braking hard! - 03.26.2009, 09:00 PM
Just made a few runs tonight on a raze st and heard a click when braking hard a couple differant times. almost sounds like a diff .hard to tell which one. whats the best way to shim diffs? lmk.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
brushlessboy16
brushlessboy16's Avatar
03.26.2009, 09:42 PM
check your output cup set screws/cvd setscrews. I had the same problem, and it ended up being a loose setscrew allowing the cup to rotate on the pinion. the screw hitting the edge of the flat spot was causing the noise
phildogg
phildogg's Avatar
03.27.2009, 09:51 AM
will check.. thanks
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
Having the same problem in the rear.
d-fly
Having the same problem in the rear. - 04.05.2009, 09:11 PM
I think it is my pinion bevel and diff bevel gear no meshing right. might need a shim.
phildogg
phildogg's Avatar
04.06.2009, 09:10 AM
yeah mine is the rear diff also. I'm going to have to get a new set of gears and then shim.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
