E-maxx aluminum flm tanny case and gmaxx single speed mesh problem -
03.23.2009, 12:30 AM
I am having trouble getting half of my fastlane machine aluminum e-maxx tranny case and gorillamaxx single speed conversion screw holes to mesh. Any suggestions?
I had the same problem with the bottom left screw, I ended up snapping the hex scew head. I emailed Rc-Mike and got no response. There goes $40 for a manufacturing fault. No happy!
E-mail Mike again- if you dont get a responce its either because
A) he didnt get it- check the announcements section for his email address.
B) he missed it- he gets ALOT of emails so might forget to respond or the message ends up in his junkmail folder.
C) You werent very polite about the problem with the parts, so he chose to ignore the email.
I would contact FLM- they have a brilliant warrenty for bad parts.
A) Sent to the correct email adresses.
B) Oldest excuss in the book and is out of my control
C) Email was very polite. Even if email wasn't polite - its not polite not to respond at all. Two wrongs don't make a right.
Will try to contact FLM. However from past experience most manufactures, they usually refer me back to the distributor where I brought it, but will try.
I'm sure Mike will respond - he might just be too busy.
Has anybody else had this issue? You that have, can you get enough holes to line up to still have a good dirt resistant seal?
