e-maxx 3905 motor question -
07.12.2009, 09:13 PM
Hey guys im going to bought a 3905 e-maxx and I need to know I got some brushless motor in my hands but I cant use it all dont have proper gearing pinion for it ... so I got a :
feigao 8xl
neu 1515 2.5d 1700kv
neu 1509 2.5d 2700kv
I dont have any gearing on my hand for run the neu 1515 2.5d 1700kv how about running the neu 1509 2.5d 2700kv ? it is enought torque for push it without overheating @ 4s on mamba max esc with bec disabled ? here some config :
Differential Ratio: 2.8461538461538463
Transmission Ratio: 1.8333333333333335
Other Ratio: 1
Spur Tooth Count: 68
Pinion Tooth Count: 17
Total Voltage: 14.8
Motor KV: 2700
Tire Diameter (inches): 5.5
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0082
Spur/Pinion Ratio: 4 : 1
Total Ratio: 20.87179 : 1
Tire Circumference (inches): 17.28 inches (438.88 mm)
Total Motor Speed: 39960 RPM
Vehicle Speed: 31.33 mph (50.32 km/h)
Effective KV Value: 2700
KT constant: 0.5 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
NEU1509F/S
1000 Watts Continuous
2000Watts - 30sec
Max rpm: 60,000
Stator Dia. 1.5"
Magnet/rotor length 0.9"
Shaft: 5mm
Shaft length: .75"
Weight, S 212g, F 225g
Dimensions 2.1"L x 1.56" dia.
07.12.2009, 11:27 PM
Mamba maxx isnt really for 1/8th scale, I'd look into a MMM. And yes, it would be enough torque but I would be watching the ESC temps very closley..... I would gear 19/68.
07.12.2009, 11:34 PM
do you think this motor would fit the stock e-maxx motor mount ? since it has large diameters ..
07.12.2009, 11:43 PM
Well, all 1500 series have a Dia. of 1.53". Yes, it will fit with the stock motor mount. You will find that a number of people here have Neu 1500 series in their emaxx's.
07.12.2009, 11:49 PM
finaly im going to use a 20t pinion I forget the maxx are 32p.
and for the e-maxx does the driveshaft diff and tranny last a long time ? on my slash @ 3s I will destroy driveshaft and yokes so much fast
07.12.2009, 11:58 PM
Yes, the emaxx is brushless ready. The drive shafts occasionally brake and that is normal unless you have steel ones. I am putting together a VXL slash right now, how often does yours break?
Z-Pinch racer
07.12.2009, 11:41 PM
I suppose you could use it, it's a higher Kv. unit, so there will be higher currents happening. Sure you can get alot of power from it, but it will heat up after a short while geared too high. 5 years ago, ppl would have thought the 1509 was a great motor for MT's... not anymore, 1515 is the standard, and even then things heat up for some setups, some ppl even moving on up to 1521.
I am running a 1512/3D (1700Kv) on 6s, when geared for 40mph, it has tremendous power (mostly on part of batteries), upwards of sucking 2300 watts from the pack! Temps are usually around 150 - 160F hard bashing...and 120 - 130F when racing at my local track (geared for 36mph), even after a 30 minute MAIN. Those temps actually surprised me, I was expecting much higher!
EDIT: Sry, this is in a BL Revo 3.3
RC-Monster RC8T
07.14.2009, 11:29 PM
If you have the 8XL and a 1515 2.5D why not run one of them instead of the 1509? If your buying the truck then you have money to spend, why not spend another couple bucks and get the right gear? Pinions might be a bit costly but the spurs are cheap. By the way, if you look through the general discussion section, I have 3 32p 5mm bore pinions I'm trying to get rid of, PM me if interested. I have a 20T, 2T, and 25T
Hybrid Mode
