9920 No Reverse???? -
03.16.2006, 11:03 PM
Okay, i just got finished programming 9920, went through all of the steps, heard all of the beeps as instructions say, then when i plug the red jumper back in, no reverse. Please help.
No, you can't drive it!!!!! These's big boi tois!!!!!
03.17.2006, 03:04 AM
Can you describe what you did?
in steps please?
03.17.2006, 12:27 PM
connected motor, turned transmitter on pulled off jumper, connected battery, waited for beep, after beep, pulled full throttle, wait for beep, then go back to neutral, wait for double beep, then done, put programming jumper back on.
03.17.2006, 12:35 PM
Yeah, that is the way you should program it to run WITHOUT reverse.. (but with the motorbrake)
Check the sticky in the brushless section.
You need to put it back to reverse, after the neutral thing. :p
03.17.2006, 01:49 PM
Yeh, its full forward - one beep, then full reverse - two beeps. Red jumper back in, programming done.
03.17.2006, 02:59 PM
I hope I didn't confuse you in pm cates. You got it in foaward only like stated above. Did you get the brakes figured out to?
03.17.2006, 04:40 PM
I got it to work, i didnt have my remote set up right, Had ABS turned on, That apparently is a NONO. Thanks for all of the help, Guys..
03.17.2006, 06:36 PM
I have to keep that in mind. I have one but never turned the abs on.
Linear Mode
