10Xl / 9920
MAXX10
MAXX10's Avatar
10Xl / 9920 - 03.10.2006, 03:33 AM
Here is what I think I am going to go with:
10 XL
9920
ubec
running 14 cells (6s lipos soon)
(1)What else do I need (like connectors)?
(2)What gears should I run?
JOHNNYMAXXIMA
RC-Monster Dual Brushless!
JOHNNYMAXXIMA's Avatar
03.10.2006, 04:29 AM
I have heard of some people using the gold connector plugs to connect their motors to the esc. But I think most of us just solder the two together. I am actually thinking of using the connectors when I swap out my dual 9L's for the 7XL's though. Just in case I swap again in the future.
As far as the gearing goes, I'll let someone else answer that one.
nl12
nl12's Avatar
03.10.2006, 05:51 AM
10 XL
9920
ubec
I think an 8xl or 9xl sounds more appropriate for that voltage, 3.5mm gold connectors, deans connectors, wire, lvc for lipos, charger/balancer for lipos; I would get strobe slipper and use the 51t mod 1 spur, I dont know what pinion would be appropriate. Hardened idler and cvds if you dont have them yet to hold the power.
coolhandcountry
coolhandcountry's Avatar
03.10.2006, 09:41 AM
If you get the wanderer motor it has the 5.5mm connector on it. You need the male part to hook up. I don't think mike has started selling these seperate. You do need some connectors for you batteries. Deans are a good choice for this. For gearing I would start at 20 51 for the 10xl. maybe a 18 51.
Peace!
Country
Help support the
Rc-Monster
Buy here
MAXX10
MAXX10's Avatar
03.10.2006, 03:27 PM
The 10xl is in stock and I"m anxious to get the truck going. Or should I wait for 8xl or 9xl?
How long is the wire on 9920? If I keep the 9920 where the evx was will I need extra wire to get to the motor? I shouldn't need any for the batteries, or do I?
Thanks in advance
maxxdude1234
maxxdude1234's Avatar
03.10.2006, 03:34 PM
For 6s lipo, the 10XL will be the best option. I'm not 100% sure that the wires on the 9920 will stretch that far. If not, you can always mount the controller elsewhere.
squeeforever
squeeforever's Avatar
03.10.2006, 05:13 PM
ok, the 10xl will be a great choice and is very nice on 12 cells just not with blistering speeds. 14 should be very nice as 16 was wicked fast. start with 20/51 (strongly recommend the strobe slipper since the pinions are cheap and you will want to go to the strobe eventually) gearing and on 6s lipo i would go down to a 18. idlers and cvds are a must.
MAXX10
MAXX10's Avatar
03.10.2006, 06:10 PM
What pinion for the 10xl, what size is the shaft?
coolhandcountry
03.10.2006, 06:17 PM
18tooth or 20 tooth with 5 mm shaft mod 1.
Peace!
Country
Help support the
Rc-Monster
Buy here
MAXX10
MAXX10's Avatar
03.12.2006, 02:37 AM
Well I placed my order ordered, the strobe slipper's out of stock. Does anyone know how long until there back in? For now what 32 pitch gear can I safely run just to get it going?
How about the robinson slipper , there's one on ebay for $25. Would it be worth it or should I wait for the strobe?
Thanks
E-maxx-kid
03.12.2006, 04:18 AM
Thanks
I would imagine it will be fine for sometime on 14 cells, mines handles 16 on a 7xl fine for now.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.12.2006, 10:01 AM
Just keep the gear mesh tight and the slipper as tight as you can and the stock setup will hold up. I am working on getting Strobe to make some more slippers, but I don't have an ETA as of yet. :(
