making mamba monster waterproof
Urgeoner
Urgeoner's Avatar
making mamba monster waterproof - 12.12.2009, 11:37 PM
will outerwears work?
Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
12.12.2009, 11:42 PM
I pulled mine out of the case and plasti-dipped everything except the heat sink. I've only run it once so far but it worked just fine.
Urgeoner
Urgeoner's Avatar
12.13.2009, 12:03 AM
like with that rubberized coating? or like liquid electrical tape? I Ebay'd 'plati dip' and got all kinds of results.
mihael
12.13.2009, 05:45 PM
here the best way to make it waterproff, i would make it next week with my mamba, with my receiver, with my servo...
http://www.youtube.com/watch?v=LUSmKAvHyEk
Urgeoner
Urgeoner's Avatar
12.13.2009, 06:22 PM
AWESOME! Thanks!
Jabe
12.14.2009, 10:59 AM
Problem realy is receiver plugs, you need to put electric grease or something like that to connectors to prevent water from making interference. Its gonna look messy after that.
Urgeoner
Urgeoner's Avatar
12.16.2009, 12:50 AM
Really? I just balloon them. Works every time!
nativepaul
nativepaul's Avatar
12.16.2009, 06:37 AM
"Problem realy is receiver plugs, you need to put electric grease or something like that to connectors to prevent water from making interference"
It's a good idea but unless you bash in an old golddust mine probably unnecessary, I waterproof my boat ESCs and RXs by totally encapsulating them with just flying leads and watercooling pipes sticking out (not good for the air cooled MMM) I have come in from several races to find a hole/split in the hull and the inside filled with water with all the electrics and wiring/plugs submerged, no grease on the plugs and its all been working just fine, just slower from the motor/coupler spinning under water and the boat weighing twice as much as normal.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
pinkpanda3310
pinkpanda3310's Avatar
12.16.2009, 08:44 AM
I stick blu-tack around the rx plugs to block dust. I don't see why it can't be used for keeping water out. Easy to put on/off and a shite load cleaner than grease.
