Go Back   RC-Monster Forums > Support Forums > Novak
NOVAK HV 4.5 Motor shaft seperated
HV-Hyper7
NOVAK HV 4.5 Motor shaft seperated - 01.15.2010, 01:36 PM
Does anyone know what sort of glue or epoxy i can use to put the magnet back on the shaft in my HV4.5? not sure why it came appart as i never got a temp reading above 120? anyway, would JB Wled work?
Thanks for any advice you might have.
HV-Hyper7
01.15.2010, 02:00 PM
Red loctite, the high-temp version would be best I believe.
J57ltr
01.15.2010, 02:04 PM
Red Locktite is a little weak in this application. Use sleeve retaining compound you can pick it up at the autoparts store.
http://www.permatex.com/products/Aut...e_Retainer.htm
Jeff
HV-Hyper7
01.15.2010, 05:37 PM
Thanks guys, i will look into the sleeve reataining compound. any tips on putting the two back together other than make sure it is in the correct place on the shaft?
Chris
01.16.2010, 08:39 PM
Nah, just make sure its not too far forward or back like you say, and make sure you let it dry fully before using it again- keep the magnets away from anything metalic too...
brushlessboy16
brushlessboy16's Avatar
01.16.2010, 08:56 PM
I use two part epoxy
himalaya
himalaya's Avatar
01.19.2010, 03:37 AM
Loctite 603, 638, 648, green magic drops. that's what we use to glue flex shaft into hard steel propeller shaft, unbelieveable strenth and shock resistance. It works only for tight matching metal parts, ideal for motor shafts.
....What a Blue Sky....
crazyjr
crazyjr's Avatar
02.11.2010, 10:39 AM
Sorry i didn't see this sooner, i used JB weld to put a bonded rotor back on a shaft in a hv 4400 motor as well as a 1200XL basic lehner. No longer have the hv but the 1200 still runs fine after two years
