more ebay madness
more ebay madness - 01.06.2010, 11:00 PM
a 5t geared for 45mph on 6s with a hobbywing 150a and a feigao 580L.
I'm a funny guy, but even I couldn't come up ith this crap-
http://cgi.ebay.com/Custom-Electric-...item20ae9429e1
it is a clean conversion, but come on, feigao???????
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
01.06.2010, 11:24 PM
i agree..its looks like a pretty clean conversion....but 6s on the EZrun and 580L motor?!?!?!......it would be a nice "roller" purchase though... :)
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
Fast5sRevo88
01.07.2010, 04:01 PM
Its actually pretty sweet with all that carbon and high dollar aluminum hop-ups, the battery arrangement is also nice, but 6s and a FEIGO (i guess this is how you spell that word that ends with an IT) is a joke. With that hot setup it can go from 0-Shit in about 4.2 seconds!
revo guy
01.07.2010, 04:49 PM
LOL just under the list of extras
"As you can see no expense was spared during the build up !."
I guess that dosent include the power system lol
bustitup
01.07.2010, 06:06 PM
you guys are nuts that 580 9l Feigao will handle 6s easy ......yes the esc may be questionable
that is an awesome rig and the seller has a great rating
my opinion anyway
Fast5sRevo88
01.07.2010, 06:07 PM
my opinion anyway
I sure hope you are bullshitting me.
bustitup
01.07.2010, 06:08 PM
on second thought that truck is big enough to mod a radiator (with fan) and small water pump to cool the esc and motor...plus that would be trick to see set up
Fast5sRevo88
01.07.2010, 06:11 PM
And u can drain the water from the cooling system and boil eggs after you run it.
scarletboa
scarletboa's Avatar
01.07.2010, 10:43 PM
01.07.2010, 09:43 PM
my opinion anyway
it's not that the motor can't handle 6s, that's no problem, it's that the motor isn't big enough to push that heavy of a vehicle, it will pull too many amps and fry the esc. A higher voltage setup and larger motor are required to get reliable performance out of something that size.
And it's not even an hpi it's a knock off.
Buy one and tell us how it does
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
01.07.2010, 06:24 PM
Everything looks pretty dang good except the Motor/ESC choice, even running on 6s is questionable.
Motor Specs:
12-32 NiMh or 4s to 8s Lipo cells in a 30"- 40" mono or hydro.
1400 - 1800 Watts Maximum with proper cooling.
45mm Diameter x 76mm long
5mm Output Shaft for use with 5mm Couplers.
25mm Mounting Hole Spacing. Uses 3mm screws.
545 grams
Recommended rpm range 25k - 35k RPM.
2-Pole Neo Magnets & Compressed Windings
Kcaz25
Kcaz25's Avatar
01.07.2010, 06:33 PM
I mean it weighs 30lbs at least right? Maybe you could pull it off with an MMM and a 1520 1800kv geared for 40mph-35 on 6s with mild break setup... like 20% brake 100% punch control and timing at 0. The upcoming HVMMM would be more decent lol with a Plettenberg Bolido!
jhautz
jhautz's Avatar
01.07.2010, 09:45 PM
It's not even a real hpi Baja. It's a chineese knock off for $1700? I'll pass.
to make it...
or break it...
Silent...But Deadly
The 580 motor is a pile of junk- as tested by a couple RCM members who said they burnt up after only a couple runs, in a mild setup. Its a feigao afterall
I'd stick a nice fat 1717 in there and a 200amp hobbycity HV boat/plane esc, then use mech brakes = made of win.
MetalMan
MetalMan's Avatar
01.07.2010, 11:01 PM
I dunno how they managed to make it work in such a heavy vehicle, but I fried one of them 580L motors with higher voltage (lower kv) and only ~15lbs and center diff 4wd. A Neu 1521 took its place and fares much better.
