hope i didnt ruin my new lipo's
josh9mille
josh9mille's Avatar
hope i didnt ruin my new lipo's - 03.14.2010, 10:44 PM
was running my truck for a bit today and had to stop when my pack was run about 80-90% through. I unplugged my batteries and plugged them back in about an hour later to finish off my run. Normally i would have just charged up the batteries but since the MMM has lipo cut off i thought i might as well finish them off. well after like 3 minutes i noticed it was going really slow like the batteries were way below my 3.3v cut-off. Anyway im thinking since i unplugged the batteries and plugged them back in when the voltage was kinda low maybe the ESC didnt recognize they were lipos and went to the nicad mode? Is that possible? I really hope i didnt ruin them, i only have 3 cycles on them. Any ideas?
sikeston34m
sikeston34m's Avatar
03.14.2010, 10:53 PM
How many cell count were you running?
The MMM always beeps the number of cells it see when you first turn it on.
It doesn't just jump to another mode. It's still in LIPO Mode.
Are you sure it wasn't just the LVC kicking in?
josh9mille
josh9mille's Avatar
03.14.2010, 10:58 PM
i run 4s and the MMM set to auto lipo with a 3.3 cut-off. Normally when the LVC kicks in it just stops. It was just running really slow and when i put that set of lipos on the charger afterwards it was reading way below what they normally are when i first hook up to the charger
sikeston34m
03.14.2010, 11:04 PM
They were reading way below what they normally are?
Did you have a volt meter? A cell voltage display?
What were they reading?
josh9mille
josh9mille's Avatar
03.14.2010, 11:15 PM
no i dont have a volt meter. the batteries read about 6.32 volts when i hooked them to my charger but that was about 30 minutes after i stopped running them so i think the voltage probably came back up a bit just from sitting.
sikeston34m
03.14.2010, 11:20 PM
If the resting voltage came back up to 6.32 volts, there shouldn't be any harm done.
They should be ok.
Balancing is always a good practice. Is your charger a balance charger or do you have a separate balancer?
I would check the balance on them when they are nearly charged again.
josh9mille
josh9mille's Avatar
03.14.2010, 11:27 PM
oh ya i didnt spare any money on the charger. Hyp Duo. However i do skimp on the batts, turnigy 5000 2s 30c. I would rather have a really good charger to charge cheapo packs than to have high dollar packs and a venom charger lol. I ALLWAYS balance charge, and they did balance out pretty good about 0.01v difference. However it did put about 70mah more back in which tells me i over discharged a little. I hope there is no long term effects though
josh9mille
josh9mille's Avatar
03.15.2010, 12:02 AM
what i would really like to know is why didnt the ESC shut down like it normaly does at 3.3v/cell? The batteries are not much concern as i got 4 of them shipped for only $140.
03.15.2010, 12:10 AM
When you plug in your battery pack, the MMM will assume a freshly charged pack, which is ~4.2v/cell. So, the MMM may see a somewhat depleted pack as a fully charged pack of lesser voltage. This is why it is best to count the beeps when arming so that you know what the ESC sees.
Finnster
KillaHurtz
Finnster's Avatar
03.15.2010, 12:14 AM
You can force it to a cell count instead of auto detect if you always use they same voltage of batts.
If you plug in a nearly dead 4S pack, it may be read as 3S and set cut off V too low.
josh9mille
josh9mille's Avatar
03.15.2010, 12:44 AM
Ok, that confirms what i was thinking, thanks!
Ya i should probably do that since i only run 4s anyway.
03.15.2010, 11:17 PM
Yeah, just set it manually for a correct 4s cutoff voltage. I have never bothered with auto lipo, but I never change cell count after i get a setup working.
I had the same issue with an almost dead flightpower pack. I ran for a while, let it sit then went back out. The battery had revived enough and cooled down so that the voltage was not dropping but it just did not have much punch. i finally gave up and put them on the charger and sure enough they were about empty. So it is always good to top off your packs after a partial run, cause unless you time your packs and know how long they run you do not really know where they are discharge wise.
