Warrranty Repair (Sidewinder)
Snowman 78
5,280 feet above sea level
Snowman 78's Avatar
Warrranty Repair (Sidewinder) - 04.06.2010, 11:26 AM
How long is the warranty for a Sidewinder ESC? I got mine new about 3 to 4 months ago, and yesterday it stopped working. I checked the motor & RX but the problem is the ESC. Running in a Slash 2wd with VXL motor and on 7 cell NIMH. When I plug the ESC in the green and yellow LED flash but the motor will not move. The steering does work. I also tried a diff RX and same thing.
I also tried to re-calibrate the ESC to RX
Brushless Rustler
AX10
Venom Creeper
Slash 2WD
Slash 4WD
04.06.2010, 09:46 PM
Standard 12 month warrenty I believe. That said:
http://www.rc-monster.com/forum/showthread.php?t=20020
"Flashing Green and Yellow = low voltage cut-off(battery)"
I'd check your esc settings & a few different batts, just in case...
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
04.06.2010, 10:29 PM
When in doubt, re-flash the firmware.
04.06.2010, 11:12 PM
Try hitting it with a hammer, repeatedly till the offending smoke comes out. Or use the search button, I have heard that works wonders.
