Cooling down a tekin Rs
brushlessboy16
brushlessboy16's Avatar
Cooling down a tekin Rs - 07.27.2010, 08:00 AM
Im Currently running my tekin Rs in an hpi blitz and it thermals about 10 minutes into a run..
Setup:
Tekin Rs Box stock setings w/ lipo cutoff
Traxxas Vxl 3500kv motor
Proline SC calibers
19/83 gearing
No binding problems on the driveline and gearing is conservative.
motor comes of the track at 150 Degrees in 95 degree ambient temps.. esc is around 150 on the outer case.
Has the stock (tiny) power capacitor, i think im going to install a larger one to help with the amp load.. does anyone have any other tips to reducing temps?
I dont have a hotwire to adjust timing or anything like that.
nuz69
nuz69's Avatar
07.27.2010, 08:14 AM
Softer punch control setup maybe, another hole in the body too ? 95F, that's an hot weather ^^
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
brushlessboy16
07.27.2010, 10:07 AM
Tell me about it, I run my MMM in my truggy without a fan and it came of the track after a long run at 200 deg and is still kicking :P
Im gonna try the capacitor first, then if I can get the case open, see if there is any way to add a heatsink to the FETS without electrocuting myself...
ta_man
07.27.2010, 08:17 AM
Setup:
Proline SC calibers
19/83 gearing
Install a small fan so it is blowing on the solder posts. These are pretty awesome (sound like a small turbine): http://cgi.ebay.com/ws/eBayISAPI.dll...m=150375007392
07.27.2010, 02:03 PM
Anyone remember the alloy case that ( I think ) was a joint venture between Mike, GriffinUR & Tekin? I wonder whatever happend to that... ( worked awesomely to keep temps down in testing ).
snellemin
2 KiloWatt RACER
snellemin's Avatar
07.27.2010, 02:28 PM
I remember the case. I need such a case for a rspro that i'm wanting to get in the very near future.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
brushlessboy16
07.27.2010, 04:39 PM
I installed 2 330uf Low ESC capacitors on the esc, testing them tommorow
