need help with steering problems
g man
need help with steering problems - 04.15.2006, 04:47 AM
i got a gorilla maxx with g3 arms i have hi tec aggress0r crx . ihave a hitec hs-645mg servo . the problem is it turn right ok but left not so good. now i have made sure that every thing from the servo to the steering blocks is not to tight or rubbing. steering seems to be a bit slow. i am thinking of changing servos what would you recomend. or what do you think the problem is
HotnCold
HotnCold's Avatar
04.15.2006, 04:53 AM
If there is no binding or rubbing - then check to make sure that your servo horn is centered so that it goes left and right equally. If its slow - are you running a ubec or a battery. If you are looking to replace the servo - JR Hitec - either one you cant go wrong - you want some torque and speed - go for around 180oz tq and .15 or better transit time at 6.0v. Hope this helps...
Hows that "Hope and Change" working out for Ya???
g man
04.15.2006, 05:04 AM
i am running a ubec and have centered the servo horn
maxxdude1234
maxxdude1234's Avatar
04.15.2006, 05:14 AM
Are you running the stock servo saver? If so, that is most likely your problem.
HotnCold
HotnCold's Avatar
04.15.2006, 05:31 AM
servo save could be it as well -
g man
04.15.2006, 05:37 AM
got a new one cant remeber the brand it was steering good 2 weeks a go but all of a sudden its turned to crap the servo saver is about 2 months old
g man
04.15.2006, 05:40 AM
i will try a new servo saver . do you think it would be the servo it seems ok with out the servo saver off it but then its not pushing the steering though
maxxdude1234
04.15.2006, 08:06 AM
If the servo saver in on the steering bellcrank (like ue/proline) then you might need to tighten it. If its one thats mounted to the servo (like the stock one), then I would suggest upgrading to ue/proline.
coolhandcountry
coolhandcountry's Avatar
04.15.2006, 03:41 PM
I like the ue or proline setup much better than a stock type. I think it does better if you have a londer link that runs across the truck to other side for steering.
Peace!
Country
Help support the
Rc-Monster
Buy here
g man
04.15.2006, 03:53 PM
starting to think it could be the servo saver . does not want to turn right but when i touch the wheels it turns more its like its binding up. but no were after the servo saver
g man
04.15.2006, 03:57 PM
are the hitec hs645 mg servos any good or not.that what igot am runing a ubec
maxxdude1234
04.15.2006, 04:14 PM
Yeah, any Hitec or JR servo will be good. If your on a budget the BMS servo's can also be quite nice. Still, the 645MG should be able to move your tires with relative ease.
coolhandcountry
04.15.2006, 04:23 PM
My 645 mg has not problem with steering my savage around.
Peace!
Country
Help support the
Rc-Monster
Buy here
