I know better but...
Big House
Big House's Avatar
I know better but... - 09.04.2013, 07:04 PM
I need a test controller and I don't have another option at the moment. But for kicks, I am going to ask the question, can a Mamba max be used as a test controller for the Monster 2200kv motor. I am testing a new install and I need a viable controller to do so. Thanks.
CF Ofna DM-1 Pro CC1717
CF Sportswerks Mayhem ST
CF Losi LST2
bdebde
That's All Folks!
bdebde's Avatar
09.04.2013, 09:06 PM
For 4s I take it? 6s would likely smoke it, but some have done it. You will need a BEC and remove the red wire from the ESC receiver plug.
Big House
Big House's Avatar
09.04.2013, 11:02 PM
It has already been modified with a Castle Bec. Tested it tonight and it worked well. Need to make some modifications to the motor mount but prelim tests indicate a go.
CF Losi LST2
09.05.2013, 06:52 AM
Back in the day (lol) most of us used them on 4s on truggies and buggies on 4s with a BEC and a fan. They also needed or liked an extra cap bank.
You can sometimes get away with 5s but might need to take a little out if the pack.
crazyjr
crazyjr's Avatar
12.25.2013, 01:01 PM
I know 4s is the upper limit now, but when the MM first came out, i abused two of them by running 5s on 7 and 9xl fegaio motors. they really took a beating. If you have the newer versions of the programming, they may be limited to 3s by the software
