Reset Mamba Monster Without Castle Link
brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
Reset Mamba Monster Without Castle Link - 12.17.2010, 03:12 AM
Just bought myself a Mamba Monster Max and put it in my REVO. Calibrated fine and everything, but with 6s A123 and a Castle 1518 (1800kv) motor geared 21/36, the truck only does about 25mph. It can't wheelie hardly at all and as soon as I touch the brakes it does everything it can to stop the motor immediately, then puts it in reverse. I'm pretty sure this is all just a programming issue, but I don't have a Castle Link handy to reprogram it. Is there any way to reset the controller to stock settings without a Castle Link? The hobby shop is closed tomorrow so I can't go up there to see if anyone has one I could borrow for 5 minutes.
Also, the fan doesn't seem to work (took it out of the case and applied 5v to it). Anyone know where I could get a cheap replacement (< $5)?
Thanks,
Brijar
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
simplechamp
simplechamp's Avatar
12.17.2010, 03:32 AM
You can program it with your transmitter.
Here is the guide from Castle (see "Manual Programming, pg. 20"): http://www.castlecreations.com/suppo...s_ed_guide.pdf
bruce750i
bruce750i's Avatar
12.17.2010, 04:21 PM
Sounds like everything is wired up backwards. Swap a motor lead and reverse your channel 2. then recalibrate.
Your using reverse for forward and forward for reverse. And it sounds like its set at 50% reverse speed. It should run faster in reverse as is. Red led means it is receiving a reverse signal from TX. Green leds means a forward signal is being received.
I don't recall the size of fan but these fans are a good replacement option.
brijar
brijar's Avatar
12.17.2010, 05:12 PM
The light blinks green when I give it throttle and it blinks red when I give it reverse, so I think everything is wired correctly. I calibrated it like the instructions said to, but I don't think that reprograms the throttle and brake curves. It seems to run about the same in reverse, but I'm not 100% sure on that so I'll go test it again soon.
Slash 2x4 LCG
Two Slash 4x4s
Rustler
Overdriven
Destroyer of Tires
Overdriven's Avatar
12.17.2010, 09:13 PM
You only calibrated the esc to the radio. You might want to check to make sure your endpoints are set to their max on the throttle channel while calibrating, might help. But with green light for throttle, that's right. I believe default settings are 75% reverse on the esc. Brake curve should be linear, and default brake setting I think is 100%, I usually end up backing it off to about 75% and it'll still lock up.
There are 3 settings for reverse, disable, delayed, and instant. Instant will reverse the motor as soon as the esc detects the motor isn't spinning. That means the truck can still be moving with the wheels locked (skidding) and itll go into reverse. In the delayed setting, the esc has to see at least one second of neutral throttle before engaging reverse, I like this setting best. It can be changed through the transmitter programming procedure, which I've never tried, but looks way too complicated for me. I'd live with it for a day until you can get a castle link, may end up making it undrivable if you mess up the transmitter programming procedure
brijar
brijar's Avatar
12.18.2010, 04:46 AM
Wow thanks! I found how to program it from the transmitter. You just have to go into calibration mode and keep holding the throttle. Then it will go through each option and you can select yes or no based on a chart of programming options from the Mamba 25 user guide. That guide only lists 5 options that you can change, but my Mamba Monster went through 8 options, so I just left the last 3 at option 1. Anyone know what those last 3 could be?
http://www.castlecreations.com/suppo...er%20Guide.pdf
Wow this thing is great! Can't wait to drive it tomorrow!
Slash 2x4 LCG
Two Slash 4x4s
Rustler
simplechamp
12.18.2010, 08:19 AM
LOL I linked the transmitter programming guide in the first response!
coolhandcountry
coolhandcountry's Avatar
12.18.2010, 08:29 AM
I think that guide was for the small mamba not the Monster.
I just got mine in yesterday.
8 is motor timing
7 is cutoff voltage
6 is dead band
5 is drag brake
4 is punch control
3 reverse amount
2 brake amount
1 brake/reverse type
brijar
brijar's Avatar
12.18.2010, 02:36 PM
Wow, fail. Thanks for the link, I had read the first part of that but must have skipped the part about manual programming. Well now I know how to program it so everything should be good from here. Thanks a lot!
Slash 2x4 LCG
Two Slash 4x4s
Rustler
